The StarTech.com DH60-THERMOMETER is a reliable handheld thermo-hygrometer that provides accurate temperature and humidity readings for a variety of environments. Designed with an easy-to-read LCD display, it allows users to monitor conditions effortlessly in both Celsius and Fahrenheit. With a wide measuring range from -10°C to 60°C and humidity levels from 0% to 100%, this device is suitable for home, office, or outdoor use. It features a low battery indicator, data hold function, and auto shut-off, ensuring that measurements are taken with ease and efficiency. This digital thermo-hygrometer is compact and portable, making it ideal for on-the-go monitoring. It meets several compliance standards including EMC, FCC, RoHS, and REACH, ensuring reliability and safety in its use. The dual capability of measuring both temperature and humidity with high accuracy and a resolution of 0.1°C and 0.1% respectively makes it an essential tool for anyone looking to maintain optimal environmental conditions.
                Accurate measurementsThis thermo-hygrometer provides precise readings with a measurement accuracy of +/- 1° for temperature and +/- 5% for humidity, making it valuable for various applications.
                User-friendly displayThe LCD display presents temperature and humidity levels clearly, allowing for easy monitoring at a glance, whether indoors or outdoors.
                Energy-efficient operationWith an auto shut-off feature, the device conserves battery life, prolonging usage time and ensuring readiness when needed.
                Versatile measurement rangeThe device can measure temperatures from -10°C to 60°C and humidity from 0% to 100%, catering to a wide range of environmental conditions.
                Convenient featuresAdditional features such as the data hold function enhance usability, making it easy to capture and retain readings for further analysis.
- StarTech.com - thermo-hygrometer
- Product Type
- Thermo-hygrometer - digital
- Measuring Functions
- Temperature, humidity
- Thermometer Scale
- Celsius, Fahrenheit
- Included Accessories
- 3 AAA batteries
- Display
- LCD
- Grey
- 2-year warranty
- 5 cm x 3 cm x 14.5 cm
- Product Type
- Installation Type
- Handheld
- Display
- LCD
- Thermometer Scale
- Data hold function, auto shut-off, low battery indicator
Weather Measuring
- Parameter
- Temperature: -10 °C to 60 °C - resolution: 0.1 °C - accuracy: +/- 1° , Humidity: 0 % to 100 % - resolution: 0.1 % - accuracy: +/- 5%
- Form Factor
- AAA type
- Required Qty
- 3
- 3 AAA batteries
- Grey
- FCC, EMC, RoHS, REACH
- 2-year warranty
- 5 cm
- 3 cm
- 14.5 cm
- 190 g
- Shipping Width
- 10.6 cm
- Shipping Depth
- 3.5 cm
- Shipping Height
- 2.1 cm
- Shipping Weight
- 200 g
|  | StarTech.com Temperature/Humidity Meter | In Stock | £23.56 |
|  | StarTech.com Handheld Sound Level Meter | In Stock | £22.91 |
