StarTech.com Table Cable Management Box
Quicklinx: CVXMWS00 Mfr#: BOX4CABLE
£55.31 ex VAT
£66.37 inc VAT
Eliminate clutter at your table or podium, by organizing and storing cables in this conference table cable management box. This cable access box offers a clutter-free solution for keeping the cables on your conference-room table or lectern out of sight but still easy to access. The box features a strong build providing a sturdy in-table cable conduit. Plus, the bezel and lid of the cable box are stylized with a brushed aluminum finish, adding character that compliments any table or lectern.
You can install the cable box into virtually any conference-room table or lectern to conceal up to nine of your AV, network or charging cables when they're not in use. The box features a discreet brushed aluminum hide-away panel that discreetly integrates into your boardroom or classroom.
When you need to access one of the cables, you can simply slide open the cover panel, and connect the necessary cable to your laptop. When you're finished, just slide the cable back into the box. The access holes at the bottom of the panel are engineered to let gravity do all the work, seamlessly guiding your cables back and concealing the cable below your table. You'll never have to worry about losing cables, plus, your cables won't tangled with each other.
StarTech.com Conference Table Cable Management Box - Table Top - Conference Room AV - Conference Table Connectivity Box (BOX4CABLE) - cable management box
Cable management box
Package Content
2 mounting brackets, 4 large nylon split bushings, 7 small nylon split bushings
Product Material
Aluminium, steel
Package Content
Product Material
Aluminium, steel
Enclosure Colour
15 °C
35 °C
10 - 70%
CVXM StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.92
CVXM StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £13.58
CVXM StarTech.com 3m (10ft) Long White Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad In Stock £20.94
CVXM StarTech.com 6 ft DisplayPort Cable with Latches - M/M In Stock £13.66
