Convert a Stereo RCA Audio signal to Digital Coax and Toslink. The AA2SPDIF Stereo RCA to SPDIF Digital Coaxial and Toslink Audio Converter lets you convert or split your analog stereo audio into 2-channel Digital Coaxial and Toslink output signals.
Perfect for many home and professional audio applications, this RCA to digital audio converter saves the cost of upgrading equipment for compatible connections, by offering a separate Digital Coax and Toslink output. For added versatility, the device can also function as an audio splitter using the digital coax and Toslink outputs simultaneously. The converter features a small form factor design that makes it suitable for installation into virtually any location regardless of space constraints, while still providing a lossless audio signal at distances up to 5 meters (15 feet). Plus, the converter supports plug-and-play installation saving you time and hassle.
- StarTech.com RCA to SPDIF Digital Coax and Toslink Optical Audio Converter - coaxial/optical digital audio converter
- Product Type
- Coaxial/optical digital audio converter
- White
- 2-year warranty
- Product Type
- White
- Connections
- Audio line-in - RCA x 2 , Digital audio output (coaxial) - RCA , Digital audio output (optical) - TOS Link
- 2 years
StarTech.com 3 ft USB to Type M Barrel 5V DC Power Cable | In Stock | £5.05 |
StarTech.com DC Power Adapter - 5V, 3A | In Stock | £11.96 |
