Portrait Kiosk Enclosure Steel For 45" to 55" Displays. The digital signage stand provides a convenient and cost-effective way to communicate with clients. Engineered with a sleek and sturdy design, the portrait kiosk enclosure provides a secure mount for a 45" to 55" TV (with maximum weight of 176 lb./80 kg) that will attract and captivate passersby.
Durable Construction
The digital signage mount features durable construction which makes it ideal for commercial use, in environments such as trade shows and retail establishments. While many kiosks have a built-in display, the LCD advertising stand display allows you to repurpose an existing display or one of your choice. Built-in cable management keeps your cables organized and hidden from view. The digital signage kiosk enclosure features a lockable cabinet for installing your computer, media player or video extender.
Easy Assembly
The flat TV stand features a solid base that provides the display with stability, perfect for use in areas with heavy traffic. The base of the touch screen kiosk stand is designed to be bolted to the floor to provide greater stability than freestanding display kiosks.
The Choice of IT Pros Since 1985
StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales.
This DSIGNAGESTND is backed by a StarTech.com 5-year warranty and free lifetime technical support.
Durable construction
The digital signage mount features durable construction which makes it ideal for commercial use, in environments such as trade shows and retail establishments. While many kiosks have a built-in display, the LCD advertising stand display allows you to repurpose an existing display or one of your choice. Built-in cable management keeps your cables organized and hidden from view. The digital signage kiosk enclosure features a lockable cabinet for installing your computer, media player or video extender. -
Easy assembly
- StarTech.com Digital Signage Display Stand - Black - Locking - floor stand
- Product Type
- Floor stand
- 35 cm x 96 cm x 194 cm
- 40 kg
- Recommended Use
- LCD display
- Recommended Display Size
- 45"-55"
- VESA Mounting Interface
- 200 x 200 mm, 400 x 200 mm, 400 x 400 mm, 600 x 400 mm, 300 x 300 mm
- Max Load Weight
- 80 kg
- Black
- Package Content
- 4 x M5x14 screws, 4 x M6x14 screws, 4 x M8x30 screws, 8 x spacers (small), hex key (4mm), 2 x cable ties, hex key (5mm), 4 x M8x50 screws, hex key (6mm), 2 x screws, 4 x rectangular washers, 2 x M4x6 screws, 8 x spacers (large), 4 x M8x60 screws, 8 x M6x15 screws, 2 x end caps, lower base board, 2 x lower columns, 4 x lower column caps, cabinet, upper base board, upper column (left), upper column (right), 2 crossbars, 2 brackets, cable bracket, 2 x locking brackets, 2 x cable clips, 2 x screw caps, 4 x M10x25 screws, 10 x M6x12 screws, 4 x M8 nuts, 2 x M6x35 screws, M6/M8 wrench, floor anchor
- 5-year warranty
- 35 cm
- 96 cm
- 194 cm
- 40 kg
- Black
- Package Content
AV Furniture
- Floor stand
- Recommended Use
- LCD display
- Cable Management
- Integrated cable management
- 45"-55"
- Max Load Weight
- 80 kg
Dimensions & Weight Details
- Shipping Dimensions (WxDxH) / Weight
- 145.2 cm x 43.5 cm x 27 cm / 44.1 kg
- Limited warranty - 5 years
