Protect your sensitive data from unauthorized access wherever you go, with this encrypted hard drive enclosure for 2.5" SATA SSDs and HDDs.
Secure Protection for Your Data
The external SSD/HDD enclosure provides reliable protection against data leaks through secure data encryption. It utilizes hardware-based 256-bit encryption, based on the Advanced Encryption Standard (AES-256), one of the most secure encryption methods. -
Fingerprint Access
With the encrypted hard drive enclosure, you can limit data access to pre-authorized individuals, by storing up to eight fingerprints for fingerprint access. There is also one master password making it easy to configure, manage and change fingerprint profiles. -
Easy and Versatile Portable Storage
Add portable external data storage to your USB-A or USB-C laptop or tablet with the encrypted SSD / HDD enclosure (two cables included). The enclosure is powered by the USB port on your device, so no external power is required. Your 2.5" SATA drive (7mm to 9.5 mm in height) slides easily into the sleek and durable aluminum enclosure, ventilated to help ensure an optimum operating temperature. Take the compact enclosure with you anywhere you go - to the office, hospital, lab, or out in the field, to access your data securely. -
Fast Performance
The encrypted drive enclosure supports USB 3.0 transfer speeds up to 5Gbps. The 2.5" SATA hard drive enclosure supports SATA I/II/III, ensuring you can achieve high performance while accessing your SATA SSD externally. The TAA compliant S251BMU3FP is backed by a StarTech.com 5-year warranty and free lifetime technical support.
- StarTech.com USB 3.0 to 2.5-inch SATA External Hard Drive Enclosure with Secure Biometric Fingerprint/Password Access for 256-bit AES Encrypted USB 3.1 Gen 1 5Gbps SSD/HDD Data Transfer - Portable Vented Aluminum Case - 8 fingerprints and permissions - OS Independent - storage enclosure - SATA 6Gb/s - USB 3.0 - TAA Compliant
- Storage enclosure - external
- Bus Type
- USB 3.0
- Black
- Expansion Bays
- 1 x internal - 2.5"
- Hard Drive Form Factor Compatibility
- 2.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 6 Gbit/s
- Supported Devices
- Hard drive, solid state drive
- Max Storage Devices Qty
- 1
- Product Material
- Plastic, aluminium
- Power Source
- USB bus
- System Requirements
- Microsoft Windows 7 / 8.1 / 10
- TAA Compliant
- 12 cm x 7.7 cm x 1.7 cm
- 95 g
- 5-year warranty
- 2.5"
- Hard Drive Maximum Height
- 9.5 mm
- Host Bus
- USB 3.0
- Product Material
- Black
Storage Controller
- Interface
- SATA 6Gb/s
- 6 Gbit/s
- Supported Devices
- 1
- Processor
- Initio INIC3637E
- Bays
- 1 x SATA 6Gb/s - SATA combo
- Connections
- 1 x USB 3.1 (Gen 1) - 10 pin Micro-USB Type B
- Included Accessories
- Screwdriver
- Cables Included
- 1 x USB 3.1 Type A to micro Type B cable - external - 50 cm , 1 x USB 3.1 Type C to micro Type B cable - external - 50 cm
- LED indicator, fingerprint lock, up to 8 fingerprints
- Mounting Kit
- Included
- MTBF
- 161709 hours
- FCC, RoHS, WEEE, AES-256, REACH
Environmental Standards
- TAA Compliant
- Power Source
- USB bus
- OS Required
- Limited warranty - 5 years
- 12 cm
- 7.7 cm
- 1.7 cm
- 95 g
- Shipping Width
- 13.2 cm
- Shipping Depth
- 17.5 cm
- Shipping Height
- 4 cm
- Shipping Weight
- 242 g
- 0 °C
- 40 °C
- 5 - 95%
StarTech.com 2 Port Flush Mount ExpressCard 54mm SuperSpeed USB 3.0 Card Adapter with UASP Support | In Stock | £31.66 |
StarTech.com 2 Port ExpressCard SuperSpeed USB 3.0 Card Adapter with UASP Support | In Stock | £26.73 |
StarTech.com 2.5in Aluminum USB 3.0 External SATA III SSD Hard Drive Enclosure with UASP for SATA 6 | In Stock | £24.45 |
StarTech.com 2.5in USB 3.0 External SATA III SSD Hard Drive Enclosure with UASP | In Stock | £19.96 |
StarTech.com 0.5m (1.5ft) Black SuperSpeed USB 3.0 Cable A to Micro B - M/M | In Stock | £8.76 |
StarTech.com 2.5in USB 3.0 SATA Hard Drive Enclosure w/ UASP for Slim 7mm SATA III SSD/HDD | In Stock | £22.08 |
StarTech.com 2m (6ft) Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M | In Stock | £12.30 |
StarTech.com 1m (3ft) Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M | In Stock | £10.63 |
StarTech.com 0.5m (20in) Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M | In Stock | £8.43 |
StarTech.com 15cm (6in) Short Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M | In Stock | £6.93 |
StarTech.com 10ft Slim Micro USB 3.0 Cable | In Stock | £15.14 |
