StarTech.com StarTech.com Biometric Enclosure USB 3.0 to 2.5" SATA
Quicklinx: FTWTWS00 Mfr#: S251BMU3FP
Type: Storage enclosure
HD Size: 2.5
Power Supply: [N/A]
£48.05 ex VAT
£57.66 inc VAT
Protect your sensitive data from unauthorized access wherever you go, with this encrypted hard drive enclosure for 2.5" SATA SSDs and HDDs.
  • Secure Protection for Your Data
    The external SSD/HDD enclosure provides reliable protection against data leaks through secure data encryption. It utilizes hardware-based 256-bit encryption, based on the Advanced Encryption Standard (AES-256), one of the most secure encryption methods.
  • Fingerprint Access
    With the encrypted hard drive enclosure, you can limit data access to pre-authorized individuals, by storing up to eight fingerprints for fingerprint access. There is also one master password making it easy to configure, manage and change fingerprint profiles.
  • Easy and Versatile Portable Storage
    Add portable external data storage to your USB-A or USB-C laptop or tablet with the encrypted SSD / HDD enclosure (two cables included). The enclosure is powered by the USB port on your device, so no external power is required. Your 2.5" SATA drive (7mm to 9.5 mm in height) slides easily into the sleek and durable aluminum enclosure, ventilated to help ensure an optimum operating temperature. Take the compact enclosure with you anywhere you go - to the office, hospital, lab, or out in the field, to access your data securely.
  • Fast Performance
    The encrypted drive enclosure supports USB 3.0 transfer speeds up to 5Gbps. The 2.5" SATA hard drive enclosure supports SATA I/II/III, ensuring you can achieve high performance while accessing your SATA SSD externally. The TAA compliant S251BMU3FP is backed by a StarTech.com 5-year warranty and free lifetime technical support.
StarTech.com USB 3.0 to 2.5-inch SATA External Hard Drive Enclosure with Secure Biometric Fingerprint/Password Access for 256-bit AES Encrypted USB 3.1 Gen 1 5Gbps SSD/HDD Data Transfer - Portable Vented Aluminum Case - 8 fingerprints and permissions - OS Independent - storage enclosure - SATA 6Gb/s - USB 3.0 - TAA Compliant
Storage enclosure - external
Bus Type
USB 3.0
Expansion Bays
1 x internal - 2.5"
Hard Drive Form Factor Compatibility
2.5"
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Hard drive, solid state drive
Max Storage Devices Qty
1
Product Material
Plastic, aluminium
Power Source
USB bus
Microsoft Windows 7 / 8.1 / 10
TAA Compliant
12 cm x 7.7 cm x 1.7 cm
95 g
5-year warranty
2.5"
Hard Drive Maximum Height
9.5 mm
Host Bus
USB 3.0
Product Material
Plastic, aluminium
Storage Controller
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
1
Initio INIC3637E
Bays
1 x internal - 2.5"
1 x SATA 6Gb/s - SATA combo
1 x USB 3.1 (Gen 1) - 10 pin Micro-USB Type B
Screwdriver
1 x USB 3.1 Type A to micro Type B cable - external - 50 cm , 1 x USB 3.1 Type C to micro Type B cable - external - 50 cm
LED indicator, fingerprint lock, up to 8 fingerprints
Mounting Kit
Included
MTBF
161709 hours
FCC, RoHS, WEEE, AES-256, REACH
Environmental Standards
TAA Compliant
Power Source
USB bus
Limited warranty - 5 years
12 cm
7.7 cm
1.7 cm
95 g
Shipping Width
13.2 cm
Shipping Depth
17.5 cm
Shipping Height
4 cm
Shipping Weight
242 g
5 - 95%
FTWT StarTech.com 2 Port ExpressCard SuperSpeed USB 3.0 Card Adapter with UASP Support In Stock £20.74
FTWT StarTech.com 0.5m (1.5ft) Black SuperSpeed USB 3.0 Cable A to Micro B - M/M In Stock £7.36
FTWT StarTech.com 2m (6ft) Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M In Stock £11.19
FTWT StarTech.com 0.5m (20in) Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M In Stock £7.91
FTWT StarTech.com 15cm (6in) Short Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M In Stock £6.29
FTWT StarTech.com 10ft Slim Micro USB 3.0 Cable In Stock £13.00
FTWT StarTech.com Rugged Hard Drive Enclosure In Stock £32.20
FTWT StarTech.com USB 3.1 Enclosure for 2.5" SSD In Stock £25.78
HD Size: 2.5
Power Supply: [N/A]
