StarTech.com StarTech.com 1m Premium HDMI 2.0 Cable w/Ethernet - 3ft HDR
Quicklinx: FTWSWS00 Mfr#: RHDMM1MPW
Length: 1m
Hurry, only 1 left in stock!
£12.62 ex VAT
£15.14 inc VAT
HIGH PERFORMANCE CABLE: 3.3 ft (1 m) Premium Certified HDMI 2.0 with Ethernet, 4K 60Hz (up to 4096x2160p), 18Gbps bandwidth, HDR10 for high contrast ratio, Ultra wide aspect ratio, 32 Ch multi-stream audio (5.1/7.1/DD+/Dolby TrueHD/Atmos) 1536Hz sampling.
DURABLE: HDMI cable w/Kevlar aramid fiber for high tensile strength & durability; Tested up to 10000+ bend cycles at 180° angle & 5000+ insertions; Al-Mylar Foil w/ Braid provides EMI shielding ensures signal integrity; Ideal for Commercial environments.
FLEXIBLE CABLE: Long lasting TPE jacket and strain relief absorbs stress of frequent bends protecting the core of the rugged UHD HDMI 34AWG cord; TPE is non-toxic, halogen free and RoHS certified for environmental sustainability.
APPLICATIONS: Ideal for home/office and travel, works with computer/laptop/desktop/workstation; Connect your TV/monitor/display/projector/soundbar; Samsung/Sony/Apple TV/Dell/LG; Compatible with HDMI 2.0 Ultra HD, 1080p Full HD and previous HDMI versions SPECS: 1 m (3.3 ft) | Black | HDMI 2.0 | HDMI Male to Male | 34 AWG | Reinforcement: Aramid Fiber | Jacket: TPE | EMI Shielding | Audio Return Channel (ARC), HDCP 2.2, CEC, BT.2020 colorimetry.
  • Built for Daily Use
    This Premium Certified HDMI cable has aramid fiber reinforcement that?braces?it from the stress of frequent bends. This also lets the cable flex without?over-stretching?or damaging?the core of the cord.
  • Flexible Strain Relief
    The cable is constructed to prevent the connector from separating from the jacket. The extra-long strain relief molding is tested to withstand over 10,000+ bend cycles at a 180° angle.
  • Connector Key Features • HDMI gold plated connector with metal shield protects the circuit board from EMI and reinforces the connection point • Strain relief tested to tolerate over 10,000+ bend cycles at a 180° angle
    Supporting all HDMI 2.0 specifications, this 3ft white HDMI Premium Certified cable?supports?resolutions up to 4k 60Hz with a bandwidth of up to 18Gbps. The short male to male HDMI cable also supports HDR for higher contrast ratio and vivid colors providing?an?enriched?and enjoyable?viewing experience. RHDMM1MPW is backed by a StarTech.com lifetime warranty and free lifetime technical support. Note: DuPont and Kevlar are trademarks or registered trademarks of E.I. du Pont de Nemours and Company.
StarTech.com 1m Premium Certified HDMI 2.0 Cable with Ethernet, Durable High Speed UHD 4K 60Hz HDR 10, 3ft Rugged M/M HDMI Cord with Aramid Fiber, TPE, Ultra HD Monitors, TVs & Displays - Heavy duty HDMI cable - HDMI cable with Ethernet - 1 m
Cable
Premium High Speed - HDMI cable with Ethernet
American Wire Gauge (AWG)
30
Length
1 m
White
Connector
HDMI - male
Connector (Second End)
HDMI - male
4K format support, HDR support, EMI/RFI protection
P/N: TB3DKM2HDL
Cable Type
30
Jacket Material
PVC
Shielding Material
Length
1 m
Plated Connector
Gold
White
Connector
19 pin HDMI Type A - male
Shipping Width
18.2 cm
Shipping Depth
15 cm
Shipping Height
2 cm
Shipping Weight
78 g
P/N: TB3DKM2HDL
Length: 1m
