The StarTech.com 10-Pack Dual-Access Laptop Lock is a comprehensive security solution designed to protect a wide array of devices from theft. This 6.5 ft (2 m) security cable lock, compatible with all K-Slot devices, offers flexibility and security for your equipment. Whether you're securing docking stations, monitors, notebooks, or printers, this lock has you covered. The package includes 10 laptop security locks, 10 hook-and-loop straps, 30 lock spacers, and 4 keys, providing everything needed for immediate setup. With the option of using a key or combination lock, it offers dual-access flexibility, making it perfect for environments where multiple users need access. The robust construction of steel and plastic ensures your devices are protected in any setting, making it an ideal choice for educational institutions, offices, and tech labs looking to safeguard their investments.
Versatile security
Designed for a wide range of devices including docking stations, monitors, notebooks, and printers, this dual-access laptop lock offers a comprehensive solution to protect valuable equipment from theft. -
Robust construction
Crafted from high-quality steel and plastic, the security cable lock is built to withstand attempts at tampering, ensuring your devices remain secure in any environment. -
Dual-access convenience
Equipped with both a combination and key lock method, this security cable lock provides flexible options for securing your devices, allowing for shared access or individual use as needed.
- StarTech.com 10-Pack Dual-Access Laptop Lock, 6.5ft (2m) Keyed Alike and Combination Security Cable Lock for K-Slot Devices, Computer Anti-Theft Steel Cable - security cable lock
- Product Type
- Security cable lock
- Packaged Quantity
- 10 (specifications are for single item)
- Package Content
- 10 Laptop Security Locks, 10 hook and loop straps, 30 lock spacers, 4 keys
- Black & silver
- Product Material
- Plastic, steel
- 5.8 cm 3.1 cm
- Length
- 2 m
- 176 g
- Kensington Standard Slot (K-Slot), theft protection
- 2-year warranty
- Packaged Quantity
- Product Type
- Product Material
- Plastic, steel
- Package Content
- 5.8 cm
- 3.1 cm
- Length
- 2 m
- 176 g
- Shipping Dimensions (WxDxH) / Weight
- 23.3 cm x 21.4 cm x 9.5 cm / 1.6 kg
- Black & silver
Security Cable Lock
- Intended For
- Docking station, monitor, notebook, printer
- Lock Type
- Wedge
- Lock Method
- Combination, key
- Limited warranty: - 2 years
- -20 °C
- 40 °C
