StarTech.com StarTech 10-Pk Laptop Lock
Quicklinx: HSVRWS00 Mfr#: DUALKA10-LAPTOP-LOCK
Hurry, only 2 left in stock!
£170.01 ex VAT
£204.01 inc VAT
The StarTech.com 10-Pack Dual-Access Laptop Lock is a comprehensive security solution designed to protect a wide array of devices from theft. This 6.5 ft (2 m) security cable lock, compatible with all K-Slot devices, offers flexibility and security for your equipment. Whether you're securing docking stations, monitors, notebooks, or printers, this lock has you covered. The package includes 10 laptop security locks, 10 hook-and-loop straps, 30 lock spacers, and 4 keys, providing everything needed for immediate setup. With the option of using a key or combination lock, it offers dual-access flexibility, making it perfect for environments where multiple users need access. The robust construction of steel and plastic ensures your devices are protected in any setting, making it an ideal choice for educational institutions, offices, and tech labs looking to safeguard their investments.
  • Versatile security
    Designed for a wide range of devices including docking stations, monitors, notebooks, and printers, this dual-access laptop lock offers a comprehensive solution to protect valuable equipment from theft.
  • Robust construction
    Crafted from high-quality steel and plastic, the security cable lock is built to withstand attempts at tampering, ensuring your devices remain secure in any environment.
  • Dual-access convenience
    Equipped with both a combination and key lock method, this security cable lock provides flexible options for securing your devices, allowing for shared access or individual use as needed.
StarTech.com 10-Pack Dual-Access Laptop Lock, 6.5ft (2m) Keyed Alike and Combination Security Cable Lock for K-Slot Devices, Computer Anti-Theft Steel Cable - security cable lock
Security cable lock
Packaged Quantity
10 (specifications are for single item)
Package Content
10 Laptop Security Locks, 10 hook and loop straps, 30 lock spacers, 4 keys
Black & silver
Product Material
Plastic, steel
5.8 cm 3.1 cm
Length
2 m
176 g
Kensington Standard Slot (K-Slot), theft protection
Packaged Quantity
Security cable lock
Product Material
Plastic, steel
Package Content
5.8 cm
3.1 cm
Length
2 m
176 g
23.3 cm x 21.4 cm x 9.5 cm / 1.6 kg
Black & silver
Security Cable Lock
Intended For
Docking station, monitor, notebook, printer
Lock Type
Wedge
Lock Method
Combination, key
Limited warranty: - 2 years
-20 °C
