StarTech.com Standing Desk Balance Board
Quicklinx: DTP3WS00 Mfr#: BALBOARD
This balance board for standing desks gives you a fun and easy way to engage both your mind and body, by providing a way to add more movement to your workday.
The balance board is designed with an unstable platform for standing. This encourages balancing movement to help to engage the stabilizing muscles in your legs and core. As a result, it can enhance your core stability and balance, and help to increase your focus and alertness.
Encourages gentle movement while standing, to help engage the stabilizing muscles in your legs and core.
Standing desk balance board rests on a spherical base, allowing a wide range of movement.
Easy to move out from under desk, with foot control.
StarTech.com Balance Board for Standing Desks or Sit-Stand Workstations - Soft Carpet Surface - Standing Desk - footrest - grey
Footrest
Grey
Material
Plastic
2 years
Footrest
Grey
Material
Plastic
Rubber feet, tilt
Warranty
2 years
Mat
Floor Type
Carpet
35 cm
50 cm
6.2 cm
2 kg
Shipping Weight
2 kg
RoHS
DTP3 StarTech.com Sit-to-Stand Workstation In Stock £121.36
DTP3 StarTech.com Sit Stand Desk Converter 35" Work Surface - Standing Desk Converter In Stock £354.22
