StarTech.com Standalone 2.5 / 3.5" SATA Hard Drive Duplicator w/  Multi HDD SSD Image Backup Library
Quicklinx: 9QVXWS00 Mfr#: SATDUP11IMG
Hurry, only 2 left in stock!
£259.99 ex VAT
£311.98 inc VAT
Duplicate one 2.5/3.5" hard drive to another without connecting to a computer, or backup multiple drive images to a library drive to restore PC/Server images easily. The SATDUP11IMG standalone SATA hard drive duplicator, lets you create an exact duplicate of a SATA hard drive (HDD) / solid state drive (SSD), or create a single backup library drive containing multiple images you can copy to additional drives at any time.
Reduce clutter with the SATDUP11IMG eliminating the number of drives required when creating backups of multiple unique drive images. Using a single backup library drive, you can store several unique drive images on a single SSD / HDD, ensuring fast duplication at 6 GBpm and minimal clutter. This is an ideal solution if you frequently re-image different computer systems, because it means you'll only have to carry a single backup library drive to restore multiple drive images onto different systems.
The versatile duplicator also offers standard one-to-one drive duplication in three different modes: file & system copy, all partitions copy and whole copy. This is ideal for one-time drive duplication, eliminating the hassle of creating a drive image for a one-time project.
With an easy-to-read LCD display and intuitive four-button menu operation, the SATDUP11IMG ensures hassle-free setup and control. The menu gives you push-button access to many value-added features that ensure simple task management such as: drive to drive duplication, drive to Image library backup and restore, and many more. It also provides numerous advanced setup options for experienced users.
The SATDUP11IMG is TAA compliant.
StarTech.com Standalone 2.5 / 3.5" SATA Hard Drive Duplicator w/ Multi HDD / SSD Image Backup Library - Hard Drive Duplicator - 6 GBpm (SATDUP11IMG) - hard drive duplicator
Hard drive duplicator
0 (installed) / 2 (max)
Supported Drives
SATA-600
North America, United Kingdom, Europe
Built-in Devices
Status LCD
Storage Controller
SATA (SATA 6Gb/s)
AC 120/230 V - 50/60 Hz
13 cm x 8 cm x 3 cm
350 g
P/N: SVA12M5NA
Enclosure Colour
Chassis
Built-in Devices
Status LCD
0
Supported Devices / Modules Qty
2
Supported Drives
SATA-600
Storage Controller
SATA
Interface Type
SATA 6Gb/s
Max Storage Devices Qty
2
Expansion Bays
2 (total) / 2 (free) x external - 2.5" / 3.5" shared
2 x SATA 6Gb/s - 22 pin Serial ATA
2 x Serial ATA cable
FCC, RoHS
External power adapter
13 cm
8 cm
3 cm
350 g
5 °C
45 °C
20 - 80%
P/N: SVA12M5NA
9QVX StarTech.com 2.5in Silicone Laptop Hard Drive Protector Sleeve with Connector Cap In Stock £4.12
9QVX StarTech.com 3.5in Silicone Hard Drive Protector Sleeve with Connector Cap In Stock £3.93
9QVX StarTech.com SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks In Stock £19.32
9QVX StarTech.com 4 Bay USB 3.0 eSATA to SATA Standalone 1:3 HDD Hard Drive Duplicator Dock In Stock £401.35
9QVX StarTech.com 2.5in SATA/SAS SSD/HDD to 3.5in SATA Hard Drive Converter In Stock £13.63
9QVX StarTech.com 2.5in SATA to Mini SATA SSD Adapter Enclosure In Stock £35.66
9QVX StarTech.com 1:2 Standalone USB 2.0 Flash Drive Duplicator and Eraser In Stock £122.58
9QVX StarTech.com Standalone 2.5 / 3.5" SATA Hard Drive Duplicator w/ Multi HDD SSD Image Backup Library In Stock £259.99
9QVX StarTech.com eSATA / USB 3.0 SATA III Hard Drive Docking Station SSD / HDD with UASP In Stock £44.05
9QVX StarTech.com eSATAp / eSATA or USB 3.0 External 2.5in SATA III 6 Gbps Hard Drive Enclosure with UASP In Stock £31.44
9QVX StarTech.com DC Power Adapter - 12V, 5A In Stock £33.16
9QVX StarTech.com M.2 SATA & M.2 NVMe Duplicator In Stock £721.64
Stock Status: In stock
