Easily duplicate or securely erase up to five USB 2.0 Flash Drives simultaneously, without connecting to a computer. The USBDUP15 OnetoFive USB flash drive duplicator and eraser lets you quickly clone up to five backups of a single USB flash drive, or securely erase up to six flash drives, without connecting the to a host computer.
Featuring a compact lightweight design that you can carry anywhere, and standalone operation that does not require a host computer, the flash drive duplicator and eraser has a small desktop footprint and is great for travel. Perfect for software and marketing content distribution in the office or on-the-go.
With an easy-to-read LCD display and intuitive four button menu operation, the USBDUP15 ensures hassle-free setup and control. The menu gives you push-button access to many value-added features that ensure simple task management such as: Capacity & Speed Check, Copy & Compare, Asynchronous Copy, and many more. It also provides numerous advanced setup options for experienced users.
This versatile device is both hard drive cloner and eraser in one, and offers two duplication modes (File & System Copy / Whole Copy) with up to1.5GB/m at Whole Copy mode. It offers three erase modes (Quick Erase / Full Erase / DoD Erase) giving you the freedom to choose the best solution for your application.
The USBDUP15 flash drive duplicator supports copying/cloning to SD/ SDHC/ Micro SD/ MMC/ Mini SD/ CF media through a USB multimedia card reader (sold separately) and to Hard Drives or Solid State Drives through a hard drive docking station or USB enclosure (sold separately)
Maximum Portability
Featuring a compact lightweight design that you can carry anywhere, and standalone operation that does not require a host computer, the flash drive duplicator and eraser has a small desktop footprint and is great for travel. Perfect for software and marketing content distribution in the office or on-the-go. -
Hassle-free Operation
With an easy-to-read LCD display and intuitive four button menu operation, the USBDUP15 ensures hassle-free setup and control. The menu gives you push-button access to many value-added features that ensure simple task management such as: Capacity & Speed Check, Copy & Compare, Asynchronous Copy, and many more. It also provides numerous advanced setup options for experienced users. -
Fast Duplication and Secure Erasing
This versatile device is both hard drive cloner and eraser in one, and offers two duplication modes (File & System Copy / Whole Copy) with up to 1.5GB/m at Whole Copy mode. It offers three erase modes (Quick Erase / Full Erase / DoD Erase) giving you the freedom to choose the best solution for your application. The USBDUP15 is TAA compliant and backed by a 2-year StarTech.com warranty and lifetime technical support. Note: The USBDUP15 flash drive duplicator supports copying/cloning to SD/ SDHC/ Micro SD/ MMC/ Mini SD/ CF media through a USB multimedia card reader (sold separately) and to Hard Drives or Solid State Drives through a hard drive docking station or USB enclosure (sold separately)
- StarTech.com Standalone 1:5 USB Flash Drive Duplicator and Eraser - Flash Drive (USB 3.0/2.0/1.1) Copier - 2 Duplication Modes (USBDUP15) - USB drive duplicator
- Black
- Installed Devices / Modules Qty
- 5 (max)
- Localisation
- North America, United Kingdom, Europe
- Built-in Devices
- Status LCD
- Power
- AC 120/230 V
- 16.7 cm x 12 cm x 2.5 cm
- 318 g
- 2-year warranty
- Enclosure Colour
- Black
- Localisation
Chassis
- Built-in Devices
- Status LCD
- Supported Devices / Modules Qty
- 5
- 6 x USB 2.0 - 4 pin USB Type A
- FCC, RoHS
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- 16.7 cm
- 12 cm
- 2.5 cm
- 318 g
- Limited warranty - 2 years
- 5 °C
- 45 °C
- 5 - 95%
StarTech.com USB 3.0 to SATA Hard Drive Docking Station for 2.5/3.5 HDD | In Stock | £40.55 |
StarTech.com 6in USB 2.0 Extension Adapter Cable A to A - M/F | In Stock | £4.61 |
StarTech.com 4 Bay USB 3.0 eSATA to SATA Standalone 1:3 HDD Hard Drive Duplicator Dock | In Stock | £411.23 |
StarTech.com 1:2 Standalone USB 2.0 Flash Drive Duplicator and Eraser | In Stock | £116.33 |
StarTech.com 2.5in Aluminum USB 3.0 External SATA III SSD Hard Drive Enclosure with UASP for SATA 6 | In Stock | £23.45 |
StarTech.com Standalone 2.5 / 3.5" SATA Hard Drive Duplicator and Eraser w/ High Duplication Speed | In Stock | £305.50 |
StarTech.com USB 3.0 SATA Hard Drive Docking Station SSD / HDD with integrated Fast Charge USB Hub | In Stock | £48.65 |
StarTech.com USB 3.0 to 2.5/3.5" SATA HDD / SSD Duplicator Dock - Standalone Hard Drive / HDD Clone | In Stock | £67.04 |
StarTech.com USB 3.0 SATA III Hard Drive Docking Station SSD / HDD with UASP | In Stock | £40.30 |
StarTech.com Standalone 1:5 USB Flash Drive Duplicator and Eraser | In Stock | £482.91 |
StarTech.com USB Duplicator and Eraser 1:15 | In Stock | £1,147.98 |
StarTech.com USB Duplicator and Eraser 1:7 | In Stock | £663.80 |
StarTech.com M.2 SATA & M.2 NVMe Duplicator | In Stock | £681.14 |
