Quicklinx: D1VVWS00 Mfr#: ST12MHDLAN4R
£259.38 ex VAT
£311.25 inc VAT
This 4K HDMI over IP receiver works with the 4K HDMI over IP Extender Kit (sold separately) and lets you extend a 4K HDMI signal, as well as RS-232 peripheral device connections, over your network. You can use additional receivers (sold separately) to distribute the HDMI signal to multiple locations, each with 4K support, and combine your remote displays to create a video wall.
The IP receiver also features RS-232 extension which enables you to add a remote serial operated device at your video source or each remote display. This HDMI over IP extender is the perfect solution for combining a serial-operated touchscreen with your display or video wall, to create interactive digital signage presentations.
You can add multiple receivers to your HDMI over IP extender kit to create a point-to-multipoint setup or video wall. In these configurations, you can also add additional sources (transmitters) with even more displays (receivers) over your Gigabit Ethernet switch with IGMP. For further scalability, you can combine up to 16 total (transmitters) and as many receivers (displays) as your network bandwidth can support.
The extender also features a separate 3.5 mm audio source that enables you to switch between the native HDMI audio and a separate 3.5 mm audio source, so you can distribute a single audio source to multiple remote locations over IP (also requires a Gigabit Ethernet switch with IGMP).
This HDMI over IP kit uses H.264 compression to deliver astonishing 4K UHD video to your remote 4K displays over an IP connection. With support for 4K, you can achieve an output resolution of up to 3840 x 2160p at 30Hz, which enables you to extend a 4K video source to multiple remote locations - perfect for digital signage or entertainment video distribution throughout large buildings such as schools, hospitals, shopping centers or areas.
The extender is backward compatible with lower resolutions such as 1080p or 720p, making it great for lower resolution applications while future-proofing your infrastructure for 4K implementation.
This HDMI distribution kit features an easy-to-use video control software app that helps you manage your IP video distribution. The app is simple to set up, with automatic hardware detection, and it lets you switch video sources for each remote display. You can also create and manage a video wall, for an impressive digital signage presentation that's sure to catch your audience's attention.
The software is available on iOS for your iPhone or iPad, Android for your smartphone or tablet, and Google Chrome browser.
The HDMI over IP extender kit includes optional slot shelf mounting hardware for a tidy installation. Plus, because the extender uses standard non-proprietary CAT5e or CAT6 Ethernet cable with RJ-45 connectors, it eliminates both the expense and hassle of running specialized cables.
The extender also features an EDID copy function, which ensures native resolution and maximum compatibility with your display or projector for a convenient plug-and-play installation.
For best performance, a managed network switch with IGMP is recommended if you are using more than one transmitter, or more than four receivers, Non-managed network switches may also limit the performance of other devices connected to the same network.
  • Ultra HD 4K resolution at 30Hz
    This HDMI over IP kit uses H.264 compression to deliver astonishing 4K UHD video to your remote 4K displays over an IP connection. With support for 4K, you can achieve an output resolution of up to 3840 x 2160p at 30Hz, which enables you to extend a 4K video source to multiple remote locations - perfect for digital signage or entertainment video distribution throughout large buildings such as schools, hospitals, shopping centers or areas. The extender is backward compatible with lower resolutions such as 1080p or 720p, making it great for lower resolution applications while future-proofing your infrastructure for 4K implementation.
  • Manage your video distribution from your mobile device
    This HDMI distribution kit features an easy-to-use video control software app that helps you manage your IP video distribution. The app is simple to set up, with automatic hardware detection, and it lets you switch video sources for each remote display. You can also create and manage a video wall, for an impressive digital signage presentation that's sure to catch your audience's attention. The software is available on iOS for your iPhone or iPad, and Android for your smartphone or tablet.
  • Professional, cost-effective, simple installation
    The HDMI over IP extender kit includes optional slot shelf mounting hardware for a tidy installation. Plus, because the extender uses standard non-proprietary CAT5e or CAT6 Ethernet cable with RJ-45 connectors, it eliminates both the expense and hassle of running specialized cables. The extender also features an EDID copy function, which ensures native resolution and maximum compatibility with your display or projector for a convenient plug-and-play installation. Download the StarTech.com Video Control software to manage your IP video distribution. The ST12MHDLAN4R is TAA compliant and backed by a StarTech.com 2-year warranty with free lifetime technical support. Note: For best performance, a managed network switch with IGMP is recommended for more than one transmitter, or more than four receivers, Non-managed network switches will also limit the performance of other devices on your network. Support for Jumboframes must be enabled to distribute 4K video.
StarTech.com 4K HDMI over IP Receiver for ST12MHDLAN4K - 4K Receiver - HDMI Over Cat6 - 4k AV Receiver (ST12MHDLAN4R) - video/audio extender - 1GbE, HDMI
Video/audio extender (receiver)
External
Australia, New Zealand, North America, United Kingdom, Europe
1GbE, HDMI
Max Transfer Distance
100 m
AC 120/230 V
13.1 cm x 13.1 cm x 2.7 cm
618 g
P/N: ST12MHDLAN4K, SV565HDIP, SVA12M2NEUA, SVA12M5NA, VIDWALLMNT
External
Wired
1GbE, HDMI
Max Resolution
3840 x 2160 @ 30 Hz
100 m
Status Indicators
Link OK
Reset button, 4K resolution support, 720p resolution support, 1080p resolution support
1 x HDMI - 19 pin HDMI Type A , 2 x - RJ-11 female , 1 x network - RJ-45 female , 1 x audio (input) - mini jack , 1 x audio (output) - mini jack , IrDA (input) , IrDA (output)
Mounting brackets, screwdriver, RJ11 to RS-232 adapter
1 x RJ-11 phone cable , 1 x network cable
FCC, RoHS, WEEE, RCM
External power adapter
Installed Qty
1
AC 120/230 V
13.1 cm
13.1 cm
2.7 cm
618 g
0 - 80%
D1VV StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.92
D1VV StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.37
D1VV StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.56
D1VV StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.97
D1VV StarTech.com 3 ft Stereo Audio Cable - 3.5mm Male to 2x RCA Male In Stock £4.94
D1VV StarTech.com 2m 6ft Premium HDMI 2.0 Cable In Stock £16.00
D1VV StarTech.com DC Power Adapter - 12V, 2A In Stock £11.76
D1VV StarTech.com DC Power Adapter - 12V, 5A In Stock £42.05
D1VV StarTech.com HDMI Over IP Extender Kit - 4K In Stock £464.90
D1VV StarTech.com ST12MHDLAN4K Receiver In Stock £259.38
D1VV StarTech.com Video Wall Mount - Steel In Stock £296.41
