Keep spare hard drive trays handy for the DRW110SATBK Mobile Rack. This spare/extra SATA hard drive caddy/drive tray can be used with StarTech.com's 5.25in SATA Hard Drive Mobile Rack Drawer (DRW110SATBK) allowing you to hot swap an additional SATA hard drive, swap operating systems, make high speed, high capacity backups or provide individual hard drives for multiple users.
To maximize performance and utilize the full speed potential of your SATA III hard drives, this HDD Backplane supports SATA III for transfer speeds up to 6 Gbps when paired with compatible controller.
- StarTech.com Spare Hard Drive Tray for the DRW110SATBK Mobile Rack - hard drive caddy
- Hard drive caddy
- Black
- Expansion Bays
- 1 x internal - 3.5"
- Compatible Bay
- 1
- Hard Drive Form Factor Compatibility
- 3.5"
- Supported Interface
- SATA 1.5Gb/s
- Drive Connector
- 7 pin Serial ATA
- Bay Connector
- 7 pin Serial ATA
- Shock protection
- Product Material
- Plastic
- 12 cm x 19.6 cm x 4.1 cm
- 0.3 kg
- 2-year warranty
- Hard drive caddy
- 3.5"
- Product Material
- Plastic
- Black
- SATA 1.5Gb/s
- Shock protection
Storage Controller
- Processor
- No CPU
- Bays
- 1 x SATA 1.5Gb/s - SATA
- Connections
- 1 storage - Serial ATA-150 - 7 pin Serial ATA
- Compatible Bay
- 1 x external
- Limited warranty - 2 years
- 12 cm
- 19.6 cm
- 4.1 cm
- 0.3 kg
