StarTech.com Solid Wiring Cable Raceway Duct Outside Elbow
Quicklinx: FY14WS00 Mfr#: CBMWD3816O
£11.89 ex VAT
£14.26 inc VAT
20 Pack Outside Elbow Connector White UL Approved. This 20-pack of raceway outside elbows works with the StarTech.com CBMWD3816 raceway system.
Join Two Raceways Together Around Corners at a 90 Degree Angle
Use these cable raceway outside elbows with the StarTech.com CBMWD3816 raceway to join two of them together and run them around corners at a 90 degree angle in your office or server room.
Industrial Strength
Made from sturdy self-extinguishing ABS that's also warp proof, these wiring duct connectors are UL approved with 94HB Flamability (Horizontal Burning) Rating.
Use in Combination with Other Raceway Accessories
Combine this coupler with other StarTech.com CBMWD3816 raceway system accessories to give your cable management solution a finished look.
The Coupler (CBMWD3816C) (20-Pack), joins two raceways together and extends the length of your raceway.
The End Piece (CBMWD3816E) (20-Pack), cleanly caps off the end of your raceway.
The Inside Elbow (CBMWD3816I), joins two raceways together inside of corners at 90 degree angle.
The Lateral Elbow (CBMWD3816L), joins two raceways together and runs them up the wall at a 90 degree angle.
The T Connector (CBMWD3816T), joins three raceways together in T-bar.
These cable management raceway outside elbows are TAA compliant and backed by a StarTech.com Lifetime warranty and free 24/5 technical support. StarTech.com has been the IT professionals choice for over 30 years.
  • Join two raceways together around corners at a 90-degree angle
    Use these cable raceway outside elbows with the raceway to join two of them together and run them around corners at a 90 degree angle in your office or server room.
  • Industrial strength
    Made from sturdy self-extinguishing ABS that's also warp-proof.
StarTech.com 20 Pack Cable Raceway Outside Corner Connectors for CBMCWD3816, Cable Management Accessories, Channel Raceway Fitting, Wiring Duct 90 Degree Outside Elbow, Plastic, UL Listed - ABS Plastic, UL94 HB (CBMWD3816O) - cable raceway outside corner - TAA Compliant
Cable raceway outside corner
Packaged Quantity
20 (specifications are for single item)
4.128 cm x 3.325 cm x 3.284 cm
7 g
Product Material
Acrylonitrile butadiene styrene (ABS)
White
TAA Compliant
P/N: CBMWD3816
Packaged Quantity
Product Material
4.128 cm
3.325 cm
3.284 cm
7 g
Enclosure Colour
White
UL rated, self-extinguishing
TAA Compliant
Shipping Width
23.2 cm
Shipping Depth
21.8 cm
Shipping Height
6.5 cm
Shipping Weight
148 g
P/N: CBMWD3816
