20 Pack Inside Elbow Connector White UL Approved. This 20-pack of raceway inside elbows work with the StarTech.com CBMWD3816 raceway system.
Join Two Raceways Together Inside Corners at a 90 Degree Angle
Use these cable raceway inside elbows with the StarTech.com CBMWD3816 raceway to join two of them together at a 90 degree angle to extend the length of your raceway inside corners of your office or server room.
Industrial Strength
Made from sturdy self-extinguishing ABS that's also warp proof, these wiring duct elbow connectors are UL approved with 94HB Flamability (Horizontal Burning) Rating.
Use in Combination with Other Raceway Accessories
Combine this inside elbow with other StarTech.com CBMWD3816 raceway system accessories to give your cable management solution a finished look.
The Coupler (CBMWD3816C) (20-Pack), joins two raceways together and extends the length of your raceway.
The End Piece (CBMWD3816E) (20-Pack), cleanly caps off the end of your raceway.
The Lateral Elbow (CBMWD3816L) (20-Pack), joins two raceways together and runs them up the wall at a 90 degree angle.
The Outside Elbow (CBMWD3816O) (20-Pack), joins two raceways together around corners at a 90 degree angle.
The T Connector (CBMWD3816T) (20-Pack), joins three raceways together in T-bar.
These cable management raceway inside elbows are TAA compliant and backed by a StarTech.com Lifetime warranty and free 24/5 technical support. StarTech.com has been the IT professionals choice for over 30 years.
- StarTech.com 20 Pack Cable Raceway Inside Corner Connectors for CBMCWD3816, Cable Management Accessories, Channel Raceway Fitting, Wiring Duct 90 Degree Inside Elbow, Plastic, UL Listed - ABS Plastic, UL94 HB (CBMWD3816I) - cable raceway inside corner - TAA Compliant
- Product Type
- Cable raceway inside corner
- Packaged Quantity
- 20 (specifications are for single item)
- 4.134 cm x 3.595 cm x 3.595 cm
- 6 g
- Product Material
- Acrylonitrile butadiene styrene (ABS)
- White
- TAA Compliant
- 2-year warranty
- Designed For
- P/N: CBMWD3816
- Packaged Quantity
- Product Type
- Product Material
- 4.134 cm
- 3.595 cm
- 3.595 cm
- 6 g
- Enclosure Colour
- White
- UL rated, self-extinguishing
- TAA Compliant
- Shipping Width
- 24.5 cm
- Shipping Depth
- 11.9 cm
- Shipping Height
- 4.2 cm
- Shipping Weight
- 128 g
- Limited warranty - 2 years
- Designed For
- P/N: CBMWD3816
StarTech.com Solid Wiring Cable Raceway Duct Inside Elbow
