StarTech.com Solid Wire Cat 6 Modular Plug
Quicklinx: BKBWWS00 Mfr#: CRJ45C6SOL50
Length: [N/A]
Colour: Clear
£15.17 ex VAT
£18.20 inc VAT
This Cat 6 RJ45 Modular Plug can be used with Cat 6 bulk cables, allowing you to easily terminate your Cat 6 cable to the exact length equired.
  • Reliable connectivity
    These RJ-45 connectors ensure a stable and efficient connection for your network, minimizing potential interruptions.
  • High-performance design
    Designed specifically for solid wire, these connectors provide excellent signal quality and reduce data loss.
  • Environmentally friendly
    Compliant with RoHS standards, these connectors are made with materials that are safe for the environment.
  • Easy installation
    Simple to use, these plugs allow for quick connections and smooth network setups.
StarTech.com Cat 6 RJ45 Modular Plug for Solid Wire - 50 Pack (CRJ45C6SOL50) - network connector - clear
Network connector - CAT 6
Packaged Quantity
50 (specifications are for single item)
Connector
RJ-45 - male
Clear
P/N: WIRC6CMPBLU
Packaged Quantity
Network Cable Type
Clear
Connector
RJ-45 - male
RoHS
P/N: WIRC6CMPBLU
BKBW StarTech.com 1000ft Cat6 Ethernet Cable CMR In Stock £302.69
Length: [N/A]
Colour: Clear
