This Cat 6 RJ45 Modular Plug can be used with Cat 6 bulk cables, allowing you to easily terminate your Cat 6 cable to the exact length equired.
Reliable connectivity
These RJ-45 connectors ensure a stable and efficient connection for your network, minimizing potential interruptions. -
High-performance design
Designed specifically for solid wire, these connectors provide excellent signal quality and reduce data loss. -
Environmentally friendly
Compliant with RoHS standards, these connectors are made with materials that are safe for the environment. -
Easy installation
Simple to use, these plugs allow for quick connections and smooth network setups.
- StarTech.com Cat 6 RJ45 Modular Plug for Solid Wire - 50 Pack (CRJ45C6SOL50) - network connector - clear
- Network connector - CAT 6
- Packaged Quantity
- 50 (specifications are for single item)
- Connector
- RJ-45 - male
- Clear
- Limited lifetime warranty
- Designed For
- P/N: WIRC6CMPBLU
- Packaged Quantity
- Network Cable Type
- Clear
- Connector
- RJ-45 - male
- RoHS
- Designed For
- P/N: WIRC6CMPBLU
StarTech.com 1000 ft Bulk Roll of Blue CMR Cat 6 Solid UTP Riser Cable | In Stock | £290.80 |
StarTech.com 1000 ft Bulk Roll of Gray CMR Cat 6 Solid UTP Riser Cable | In Stock | £298.00 |
StarTech.com 1000ft Cat6 Ethernet Cable CMR | In Stock | £298.00 |
