StarTech.com SlimPort / MyDP to HDMI Video Adapter Converter  – 1080p
Quicklinx: 8ZCRWS00 Mfr#: SLMPT2HD
Select:
  • HDMI
Connect your SlimPort or MyDP enabled mobile device to an HDTV, monitor or projector using HDMI. The SLMPT2HD Micro USB to HDMI Adapter enables you to connect a Slimport or MyDP-enabled smartphone or tablet to any HDMI-enabled TV, monitor or projector.
The Slimport to HDMI adapter supports High-Definition 1080p output resolution and 7.1 channel digital audio, to deliver on both quality and convenience.
This compact, active adapter offers a Micro USB port on the side, for the added benefit of simultaneously charging your connected mobile device, so it is always ready to use.
StarTech.com SlimPort MyDP to HDMI Video Adapter Converter - 1080p - external video adapter - black
External video adapter
Bus Type
SlimPort (5 pin Micro-USB)
Interfaces Details
USB , HDMI , USB
2.6 cm 1.2 cm
Length
16.7 cm
Enclosure Colour
Bus Type
Interfaces Details
USB , HDMI , USB
FCC, RoHS
2.6 cm
1.2 cm
Length
16.7 cm
20 g
Enclosure Colour
5 °C
95 °C
20 - 80%
8ZCR StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.92
