Convert a VGA male connector into a VGA female connector. The GC15HSF Slimline Gender Changer (HDDB15F to HDDB15F) converts a High Density DB15 male connector to a High Density DB15 female connector.
- StarTech.com Slimline VGA HD15 Gender Changer - F/F - HD15 gender changer - VGA coupler - VGA gender changer (GC15HSF) - VGA gender changer
- Connector
- HD-15 (VGA) - female
- Connector (Second End)
- Limited lifetime warranty
- Designed For
- P/N: DP2VGAMM6B, HD2VGAMM6, MXT101MMHQ40, MXT101MMHQ45, MXT101MMHQ55, MXT101MMHQ60, MXTHQMM10MA, MXTHQMM15A, MXTHQMM15MA, MXTHQMM25A, MXTHQMM2MA, MXTHQMM30A, MXTHQMM35A, MXTHQMM50A, MXTHQMM5MA, MXTMMHQ10M, MXTMMHQ15M, MXTMMHQ20M, MXTMMHQ25M, MXTMMHQ2M, MXTMMHQ30M, MXTMMHQ3M, MXTMMHQ5M, MXTMMHQ7M
- Connector
- 15 pin HD D-Sub (HD-15) - female
- Designed For
- P/N: DP2VGAMM6, DP2VGAMM6B, HD2VGAMM6, MXT101MM, MXT101MMHD15, MXT101MMHD6, MXT101MMHQ1, MXT101MMHQ20, MXT101MMHQ30, MXT101MMHQ40, MXT101MMHQ45, MXT101MMHQ55, MXT101MMHQ60, MXTHQMM10MA, MXTHQMM15A, MXTHQMM15MA, MXTHQMM25A, MXTHQMM2MA, MXTHQMM30A, MXTHQMM35A, MXTHQMM50A, MXTHQMM5MA, MXTMMHQ10M, MXTMMHQ15M, MXTMMHQ20M, MXTMMHQ25M, MXTMMHQ2M, MXTMMHQ30M, MXTMMHQ3M, MXTMMHQ5M, MXTMMHQ7M
