StarTech.com Slim USB 3.0 to VGA External Video Card Multi Monitor Adapter – 1920x1200 / 1080p
Quicklinx: 98FXWS00 Mfr#: USB32VGAES
£19.75 ex VAT
£23.70 inc VAT
Connect a VGA display through this slim USB 3.0 Adapter for a multi-monitor solution ideal for your Ultrabook or Laptop. The USB32VGAES Slim USB 3.0 to VGA Adapter turns a USB 3.0 port into a VGA output port with 1920x1200/1080p video support. The adapter minimizes clutter with a slim design that seamlessly blends with your video cable - an ideal space-saving solution for multi-monitor applications on Ultrabook, laptop, or desktop computers.
Functioning as an external graphics card, this USB to VGA adapter provides a convenient way to add multi-monitor capability to a USB 3.0-enabled desktop or laptop computer (optimal performance from USB 3.0, backward compatible with USB 2.0).
To save space while traveling, this ultra-portable USB to VGA adapter features a lightweight, small footprint design that fits easily in a laptop carrying bag.
Leveraging the high-bandwidth (5 Gbps) SuperSpeed USB 3.0 interface, the adapter delivers smooth, high-definition content to your VGA display/projector. The adapter can be used to mirror your primary desktop, showing the same image on each display, or to extend your desktop to double your workspace and increase your productivity.
StarTech.com USB 3.0 to VGA Adapter - Slim Design - 1920x1200 - adapter - VGA / USB - TAA Compliant - 19 cm
Cable
Adapter - VGA / USB
TAA Compliant
Max Output Resolution
1920 x 1200
Length
19 cm
Connector
USB Type A - male (input)
Connector (Second End)
HD-15 (VGA) - female (output)
USB 2.0/ USB 3.0
USB powered, slim
P/N: MXT101MM
Cable Type
Adapter
Interface Supported
VGA / USB
Jacket Material
Plastic
USB 2.0/ USB 3.0
Length
19 cm
USB powered, slim
Adapters & Converters
1920 x 1200
Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10
Connector
9 pin USB Type A - male (input)
15 pin HD D-Sub (HD-15) - female (output)
WHQL, FCC, RoHS, WEEE, REACH, RCM
TAA Compliant
2.5 cm
1.2 cm
25 g
Shipping Width
17.1 cm
Shipping Depth
15.1 cm
Shipping Height
3.2 cm
Shipping Weight
148 g
P/N: MXT101MM
98FX StarTech.com USB to VGA Multi Monitor External Video Adapter In Stock £15.77
98FX StarTech.com USB to VGA External Video Card Multi Monitor Adapter – 1920x1200 In Stock £12.18
98FX StarTech.com Slim USB 3.0 to VGA External Video Card Multi Monitor Adapter – 1920x1200 / 1080p In Stock £19.75
98FX StarTech.com USB 3.0 VGA Video Adapter In Stock £17.38
98FX StarTech.com USB 3.0 to DisplayPort Adapter In Stock £56.74
98FX StarTech.com USB 3.0 to HDMI VGA Adapter - 4K 30 - External Video & Graph In Stock £63.24
