StarTech.com Slim USB 3.0 to HDMI External Video Card Multi Monitor Adapter – 1920x1200 / 1080p
Quicklinx: 97QKWS00 Mfr#: USB32HDES
40 In Stock
£26.54 ex VAT
£31.84 inc VAT
Connect an HDMI display through this slim USB 3.0 Adapter for a multi-monitor solution ideal for your Ultrabook or Laptop. The USB32HDES Slim USB 3.0 to HDMI Adapter turns a USB 3.0 port into an HDMI output with 1920x1200/1080p video support. The adapter minimizes clutter with a slim design that seamlessly blends with your video cable - an ideal space-saving solution for multi-monitor applications on Ultrabook, laptop, or desktop computers.
Functioning as an external graphics card, this USB to HDMI adapter provides a convenient way to add multi-monitor capability to a USB 3.0-enabled desktop or laptop computer (optimal performance from USB 3.0, backward compatible with USB 2.0).
To save space while traveling, this ultra-portable USB to HDMI adapter features a lightweight, small footprint design that fits easily in a laptop carrying bag.
Leveraging the high-bandwidth (5 Gbps) SuperSpeed USB 3.0 interface, the adapter delivers smooth, high-definition content to your HDMI display/projector. The adapter can be used to mirror your primary desktop, showing the same image on each display, or to extend your desktop to double your workspace and increase your productivity.
  • Efficient performance
    Delivers maximum output resolution of 1920 x 1200, allowing for clear and detailed visuals.
  • Versatile connections
    Compatible with various USB standards, it connects to different devices without hassle.
  • Enhanced audio capabilities
    Multi-channel audio support ensures an immersive sound experience to complement high-quality visuals.
  • Reliable construction
    Made from durable plastic, the adapter is designed for longevity and performance.
  • Compliance assurance
    Meets several compliance standards such as FCC, RoHS, and WHQL, ensuring quality and safety.
StarTech.com USB 3.0 to HDMI Adapter, 1080p (1920x1200), Slim/Compact USB to HDMI Display Adapter Converter for Monitor, USB Type-A External Video & Graphics Card, Black, Windows Only - USB to HDMI Adapter (USB32HDES) - adapter cable - HDMI / USB - TAA Compliant - 19 cm
Cable
Adapter cable - HDMI / USB
TAA Compliant
Max Output Resolution
1920 x 1200
Length
19 cm
Connector
USB Type A - male (input)
Connector (Second End)
HDMI - female (output)
USB 2.0/ USB 3.0
1080p support
P/N: HDDVIMM3, HDMIDVIMM10, HDMIDVIMM6, HDMM10, HDMM12, HDMM15, HDMM1MP, HDMM25, HDMM2M, HDMM2MP, HDMM3, HDMM3MP, HDMM50, HDMM50A, HDMM6, HDPMM50
Cable Type
Adapter cable 1080p support
Interface Supported
HDMI / USB
Jacket Material
Plastic
USB 2.0/ USB 3.0
Length
19 cm
Slim, multi-channel audio
Adapters & Converters
1920 x 1200
Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10
Connector
9 pin USB Type A - male (input)
19 pin HDMI Type A - female (output)
WHQL, FCC, RoHS, WEEE, REACH, RCM
TAA Compliant
2.5 cm
1.2 cm
25 g
Shipping Width
14.8 cm
Shipping Depth
17.5 cm
Shipping Height
3.2 cm
Shipping Weight
144 g
97QK StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.92
97QK StarTech.com USB 3.0 to HDMI and DVI Dual Monitor External Video Card Adapter In Stock £63.27
97QK StarTech.com 5m High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M In Stock £9.80
97QK StarTech.com USB 3 to HDMI w/ USB Hub In Stock £59.33
97QK StarTech.com Slim USB 3.0 to HDMI External Video Card Multi Monitor Adapter – 1920x1200 / 1080p In Stock £26.54
97QK StarTech.com USB 3.0 to HDMI External Multi Monitor Video Graphics Adapter for Mac & PC In Stock £47.72
97QK StarTech.com USB 3.0 to Dual HDMI Adapter In Stock £35.15
97QK StarTech.com USB 3.0 to DisplayPort Adapter In Stock £52.72
97QK StarTech.com USB to Dual DisplayPort 4K 60Hz In Stock £78.39
97QK StarTech.com 6ft Premium Certified HDMI 2.0 In Stock £12.98
