Connect an HDMI display through this slim USB 3.0 Adapter for a multi-monitor solution ideal for your Ultrabook or Laptop. The USB32HDES Slim USB 3.0 to HDMI Adapter turns a USB 3.0 port into an HDMI output with 1920x1200/1080p video support. The adapter minimizes clutter with a slim design that seamlessly blends with your video cable - an ideal space-saving solution for multi-monitor applications on Ultrabook, laptop, or desktop computers.
Functioning as an external graphics card, this USB to HDMI adapter provides a convenient way to add multi-monitor capability to a USB 3.0-enabled desktop or laptop computer (optimal performance from USB 3.0, backward compatible with USB 2.0).
To save space while traveling, this ultra-portable USB to HDMI adapter features a lightweight, small footprint design that fits easily in a laptop carrying bag.
Leveraging the high-bandwidth (5 Gbps) SuperSpeed USB 3.0 interface, the adapter delivers smooth, high-definition content to your HDMI display/projector. The adapter can be used to mirror your primary desktop, showing the same image on each display, or to extend your desktop to double your workspace and increase your productivity.
Efficient performance
Delivers maximum output resolution of 1920 x 1200, allowing for clear and detailed visuals. -
Versatile connections
Compatible with various USB standards, it connects to different devices without hassle. -
Enhanced audio capabilities
Multi-channel audio support ensures an immersive sound experience to complement high-quality visuals. -
Reliable construction
Made from durable plastic, the adapter is designed for longevity and performance. -
Compliance assurance
Meets several compliance standards such as FCC, RoHS, and WHQL, ensuring quality and safety.
- StarTech.com USB 3.0 to HDMI Adapter, 1080p (1920x1200), Slim/Compact USB to HDMI Display Adapter Converter for Monitor, USB Type-A External Video & Graphics Card, Black, Windows Only - USB to HDMI Adapter (USB32HDES) - adapter cable - HDMI / USB - TAA Compliant - 19 cm
- Cable
- Adapter cable - HDMI / USB
- TAA Compliant
- Max Output Resolution
- 1920 x 1200
- Length
- 19 cm
- Black
- Connector
- USB Type A - male (input)
- Connector (Second End)
- HDMI - female (output)
- USB 2.0/ USB 3.0
- 1080p support
- 2-year warranty
- Designed For
- P/N: HDDVIMM3, HDMIDVIMM10, HDMIDVIMM6, HDMM10, HDMM12, HDMM15, HDMM1MP, HDMM25, HDMM2M, HDMM2MP, HDMM3, HDMM3MP, HDMM50, HDMM50A, HDMM6, HDPMM50
- Cable Type
- Adapter cable 1080p support
- Interface Supported
- HDMI / USB
- Jacket Material
- Plastic
- USB 2.0/ USB 3.0
- Length
- 19 cm
- Slim, multi-channel audio
- Black
Adapters & Converters
- 1920 x 1200
- OS Required
- Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10
- Connector
- 9 pin USB Type A - male (input)
- 19 pin HDMI Type A - female (output)
- WHQL, FCC, RoHS, WEEE, REACH, RCM
- TAA Compliant
- 2.5 cm
- 1.2 cm
- 25 g
- Shipping Width
- 14.8 cm
- Shipping Depth
- 17.5 cm
- Shipping Height
- 3.2 cm
- Shipping Weight
- 144 g
- Limited warranty - 2 years
- Designed For
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £7.92 |
StarTech.com USB 3.0 to HDMI and DVI Dual Monitor External Video Card Adapter | In Stock | £42.49 |
StarTech.com 5m High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M | In Stock | £14.74 |
StarTech.com USB 3 to HDMI w/ USB Hub | In Stock | £60.64 |
StarTech.com Slim USB 3.0 to HDMI External Video Card Multi Monitor Adapter – 1920x1200 / 1080p | In Stock | £23.14 |
StarTech.com USB 3.0 to HDMI External Multi Monitor Video Graphics Adapter for Mac & PC | In Stock | £48.92 |
StarTech.com USB 3.0 to Dual HDMI Adapter | In Stock | £36.04 |
StarTech.com USB to Dual DisplayPort 4K 60Hz | In Stock | £84.19 |
StarTech.com 6ft Premium Certified HDMI 2.0 | In Stock | £12.98 |
