Split one headphone jack into two separate jacks. The MUY1MFFS Slim 3.5mm Stereo Splitter Cable/Y-cable features one 3.5 mm male and two 3.5 mm female audio connectors, splitting a single headphone jack into two.
A practical, cost-effective audio solution, the 3.5 mm stereo splitter cable features slim connector molding that fits easily into a 3.5 mm headphone jack, even if the iPod/iPhone/iPad/MP3 player is in a protective case.
Streamlined design
The slim design of the cable allows for convenient handling and storage, making it easy to take anywhere. -
Durable construction
Molded connectors and strain relief provide enhanced durability, ensuring the cable withstands regular use. -
Clear audio performance
Nickel plating on the connectors minimizes interference, delivering quality sound for an enjoyable listening experience.
- StarTech.com 3.5mm Audio Extension Cable - Slim Audio Splitter Y Cable and Headphone Extender - Male to 2x Female AUX Cable (MUY1MFFS) - audio splitter - 20 cm
- Cable
- Audio splitter
- American Wire Gauge (AWG)
- 28
- Length
- 20 cm
- Black
- Connector
- Mini-phone stereo 3.5 mm - male
- Connector (Second End)
- 2 x mini-phone stereo 3.5 mm - female
- Moulded, strain relief
- Limited lifetime warranty
- Designed For
- P/N: MU15MMS, MU6MMS
- Cable Type
- Audio splitter
- 28
- Jacket Material
- PVC
- Length
- 20 cm
- Plated Connector
- Nickel
- Black
- Connector
- Limited warranty - lifetime
- Designed For
StarTech.com 6in Stereo Splitter Cable - 3.5mm Male to 2x 3.5mm Female | In Stock | £2.68 |
StarTech.com 3.5mm 4 Position to 2x 3 Position 3.5mm Headset Splitter Adapter - F/M | In Stock | £7.79 |
StarTech.com 3.5mm 3 Pin Headset Splitter | In Stock | £3.64 |
StarTech.com Slim Stereo Splitter Cable - 3.5mm Male to 2x 3.5mm Female | In Stock | £4.76 |
StarTech.com 4 Position to 2x 3 Pin 3.5mm Headset Splitter Adapter - White | In Stock | £3.46 |
