StarTech.com Single Server KVM Console for Server Rack -19"
Quicklinx: DKZZWS00 Mfr#: RKCONS1901
Product Type: Rack, Rack
£749.12 ex VAT
£898.94 inc VAT
This rack-mount KVM console provides complete keyboard, monitor and mouse control for a single server or multiple servers.
  • Maximize your IT budget, minimize your hassle
    This KVM console provides all the essential controls you'll need to manage your server room at a low cost. The console features a built-in keyboard and a touchpad for intuitive control, as well as an LCD display.
  • Maximize your screen space
    This versatile LCD console has a 19" screen. The increased screen space allows you to run multiple applications on the same screen, increasing your productivity.
  • Clutter-free monitoring
    The rackmount LCD console slides out from 1U of rack space, enabling you to easily monitor and control a single server or multiple servers when connected through a KVM switch. The rackmount VGA console features a handle that makes it easy to slide the console in and out of the server rack.
  • Hassle-free system integration
    The rack console features a single-port KVM module, which enables you to connect it directly to a server. The module offers the flexibility you need to easily integrate it into your existing server infrastructure.
StarTech.com Rackmount KVM Console, Single Port VGA KVM with 19" LCD Monitor for Server Rack, Fully Featured Universal 1U LCD KVM Drawer with Cables & Hardware, USB Support, 50,000 MTBF - LCD KVM Concole Drawer (RKCONS1901) - KVM console - 19"
KVM console - 19"
KVM Switch
USB
Keyboard, touchpad
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
16.7 million colours
Input Connectors
VGA
48.3 cm x 53.3 cm x 4.3 cm
Height (Rack Units)
1U
12.2 kg
Australia, Japan, New Zealand, North America, United Kingdom, Europe
UL, FCC, RoHS, WEEE, PSE Mark, RCM
Display Type
KVM console / TFT active matrix
Diagonal Size
19"
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Height (Rack Units)
1U
12.2 kg
Input
Keyboard, touchpad
KVM
Keyboard / Mouse Interface
USB
Max Resolution
1280 x 1024
VGA , USB , KVM
12 x mounting rails, 8 x M5 cage nuts, 8 x M5 screws
1 x keyboard / mouse / video cable
Rack Mounting Kit
Included
MTBF
50,000 hour(s)
DKZZ StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSD In Stock £464.07
DKZZ StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD In Stock £280.59
DKZZ StarTech.com 8 Port KVM Console for Server Rack - 19in In Stock £1,162.96
DKZZ StarTech.com Single Server KVM Console for Server Rack -19" In Stock £749.12
DKZZ StarTech.com 16 port KVM VGA Console with KVM Switch - 19" In Stock £1,320.56
DKZZ StarTech.com Single Port Server KVM console with KVM Switch In Stock £655.56
DKZZ StarTech.com 17" Dual Rail Rackmount KVM Console with 1080p In Stock £927.37
DKZZ StarTech.com Rackmount KVM Console - 8 Ports with 17" LCD Monitor In Stock £999.35
DKZZ StarTech.com Rackmount KVM Console - 16 Ports with 17" LCD Monitor In Stock £1,158.04
DKZZ StarTech.com 1U HD Single Server KVM In Stock £803.46
DKZZ StarTech.com 10 ft. (3 m) USB KVM Cable for Rackmount Consoles In Stock £30.11
DKZZ StarTech.com 15 ft. (4.6 m) USB KVM Cable for Rackmount Consoles In Stock £40.34
DKZZ StarTech.com 6 ft. (1.8 m) USB KVM Cable for Rackmount Consoles In Stock £17.59
Product Type: Rack
Product Type: Rack
Price Range Ex VAT: £500 - £750
