Providing centralized control of your PC, server, or KVM switch, this single-port rackmount KVM console gives you easy access to your connected system. With a minimal footprint, it mounts in a server rack or cabinet using only 1U of rack space.
The 1U rackmount console features a built-in keyboard, a touchpad for intuitive control, and a 17-inch LCD display that supports resolutions up to 1280x1024.
This single-port KVM console includes everything you need to set up right out of the box: 1 VGA KVM Cable; Mounting Rails; M5 Cage Nuts and Screws.
The rack console features a single-port KVM module, which can be connected directly to a server or PC, or to a KVM switch for access to multiple systems. The KVM module offers the flexibility you need for easily integrating the console into your existing server infrastructure.
Rack consoles provide convenient, rack-mounted control options for single servers or entire server rooms. KVM consoles include LCD display, keyboard, and trackpad, all sliding into 1U of rack space.
Efficient design
The Rackmount KVM Console features a fully featured universal 1U LCD KVM drawer design, making it an efficient space-saving solution for managing servers. -
High-quality display
Equipped with a 17-inch TFT active matrix display that supports 16.7 million colors, the console offers a native resolution of 1280 x 1024. Its raised bezel type and 5:4 image aspect ratio ensure clear and vibrant visuals from any viewing angle. -
Durable and reliable
Designed for longevity in demanding environments, the console boasts a mean time between failures (MTBF) of 50,000 hours, ensuring reliability and performance. -
Versatile connectivity
This KVM console supports a VGA interface and USB for keyboard and mouse connections, accommodating a wide range of hardware configurations. -
Easy installation
With a rack mounting kit included and a height of only 1 rack unit (1U), the console is easy to install, making it an ideal choice for any server room or data center.
- StarTech.com Rackmount KVM Console, Single Port VGA KVM with 17" LCD Monitor for Server Rack, Fully Featured Universal 1U LCD KVM Drawer with Cables & Hardware, USB Support, 50,000 MTBF - LCD KVM Concole Drawer (RKCONS1701) - KVM console - 17"
- KVM console - 17"
- KVM Switch
- USB - 1 ports
- Keyboard, touchpad
- Aspect Ratio
- 5:4
- Native Resolution
- 1280 x 1024 at 60 Hz
- Pixel Pitch
- 0.264 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- 16.7 million colours
- Input Connectors
- VGA
- Voltage
- AC 120/230 V
- Black
- 44.8 cm x 47.1 cm x 4.25 cm
- Height (Rack Units)
- 1U
- 11.7 kg
- Localisation
- Australia, Japan, New Zealand, United Kingdom, Europe, North Asia
- 2-year warranty
- Display Type
- KVM console / TFT active matrix
- Diagonal Size
- 17"
- Aspect Ratio
- 5:4
- Native Resolution
- Pixel Pitch
- 0.264 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Black
- 1U
- 11.7 kg
Input
KVM
- KVM switch - 1 ports
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 1280 x 1024 @ 60 Hz
- VGA
- Included Accessories
- 8 x M5 cage nuts, 8 x M5 screws, 2 x mounting rails
- Cables Included
- 1 x keyboard / mouse / video cable - 1.83 m
- Rack Mounting Kit
- Included
- MTBF
- 50,000 hour(s)
- Localisation
- Input Voltage
- AC 120/230 V
- Power Consumption (Typical)
- 13 Watt
- Shipping Weight
- 17.1 kg
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSD | In Stock | £452.75 |
StarTech.com 8 Port Rackmount USB VGA KVM Switch w/ Audio (Audio Cables Included) | In Stock | £335.92 |
StarTech.com 16 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables | In Stock | £514.22 |
StarTech.com 4 Port 1U Rackmount USB KVM Switch with OSD | In Stock | £142.79 |
StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD | In Stock | £278.07 |
StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables | In Stock | £309.46 |
StarTech.com 17" Dual Rail Rackmount KVM Console with 1080p | In Stock | £919.04 |
StarTech.com Rackmount KVM Console - 8 Ports with 17" LCD Monitor | In Stock | £974.99 |
StarTech.com Rackmount KVM Console - 16 Ports with 17" LCD Monitor | In Stock | £1,083.73 |
StarTech.com 15 ft. (4.6 m) USB KVM Cable for Rackmount Consoles | In Stock | £39.35 |
StarTech.com 6 ft. (1.8 m) USB KVM Cable for Rackmount Consoles | In Stock | £17.16 |
