78 in. (2 m) Self-Extinguishing PVC M1 Rated NF Fire Resistant. This 72 in. (1.83 m) cable management raceway neatly routes cables in your office or server room, while also concealing them to create a tidy and professional look.
Professionally Organize & Route Cables
This cable management raceway protects cables from damage while neatly routing them in your office or server room. The raceway is 0.77 in. (19.6 mm) x 1.25 in. (31.8 mm). The raceway also features a durable one-piece design that opens on one side, enabling you to easily add or remove cables without the hassle of removing the raceway cover/lid.
Hassle-Free Installation
With an adhesive backing, the cable raceway can be installed by simply peeling off the protective backing and sticking it to your desired location on any surface, including wood, drywall, glass or masonry.
Industrial Strength
Made from self extinguishing PVC, that's sturdy and warp proof this network/power cable hider/concealer is M1 Rating NF fire resistant with a 186F (86C) Vicat softening point and are UL/94V-0 Rated.
This cable management raceway is TAA compliant and backed by a StarTech.com Lifetime warranty and free 24/5 technical support. StarTech.com has been the IT professionals choice for over 30 years.
Professionally organize & route cables with slotted design
This cable management raceway protects cables from damage while neatly routing them in your office or server room. The raceway is 0.77 in. (19.6 mm) x 1.25 in. (31.8 mm). The raceway also features a durable one-piece design that opens on one side, enabling you to easily add or remove cables without the hassle of removing the raceway cover/lid. -
Hassle-free installation
With an adhesive backing, the cable raceway can be installed by simply peeling off the protective backing and sticking it to your desired location on any surface, including wood, drywall, glass or masonry. -
Industrial strength
- StarTech.com Solid Cable Management Raceway with Adhesive Tape & Cover, 1-1/8"(32mm)W x 3/4"(20mm)H, 6ft(1.8m) length, PVC Network/Power Cord Hider Kit, Wall Wire Duct System, UL Listed - UL94 V0, M1 Fire Rated (CBMOWD3220) - cable raceway - TAA Compliant
- Product Type
- Cable raceway
- 3.18 cm 1.96 cm
- Length
- 2 m
- 390 g
- Product Material
- PVC
- White
- TAA Compliant
- 2-year warranty
- Product Type
- Cable raceway
- Product Material
- PVC
- 3.18 cm
- 1.96 cm
- Length
- 2 m
- 390 g
- Enclosure Colour
- White
- Self-extinguishing, adhesive tape, M1 Rated NF Fire Resistant
- TAA Compliant
- Limited warranty - 2 years
StarTech.com Single Piece Wire Cable Raceway Duct - 20x13mm | In Stock | £7.74 |
