StarTech.com Single Piece Wire Cable Raceway Duct - 20x13mm
Quicklinx: FXZZWS00 Mfr#: CBMOWD2013
£7.74 ex VAT
£9.28 inc VAT
78 in. (2 m) Self-Extinguishing PVC M1 Rated NF Fire Resistant. This 72 in. (1.83m) cable management raceway neatly routes cables in your office or server room, while also concealing them to create a tidy and professional look.
Professionally Organize & Route Cables
This cable management raceway protects cables from damage while neatly routing them in your office or server room. The raceway is 0.54 in. (13.8 mm) x 0.76 in. (19.5 mm). The raceway also features a durable one-piece design that opens on one side, enabling you to easily add or remove cables without the hassle of removing the raceway cover/lid.
Hassle-Free Installation
With an adhesive backing, the cable raceway can be installed by simply peeling off the protective backing and sticking it to your desired location on any surface, including wood, drywall, glass or masonry.
Industrial Strength
Made from self extinguishing PVC, that's sturdy and warp proof this network/power cable hider/concealer is M1 Rating NF fire resistant with a 186F (86C) Vicat softening point and are UL/94V-0 Rated.
This cable management raceway is TAA compliant and backed by a StarTech.com Lifetime warranty and free 24/5 technical support. StarTech.com has been the IT professionals choice for over 30 years.
  • Professionally organize & route cables
  • Hassle-free installation
  • Industrial strength
StarTech.com Solid Cable Management Raceway with Adhesive Tape & Cover, 3/4"(19mm)W x 1/2"(13mm)H, 6ft(1.8m) length, PVC Network/Power Cord Hider Kit, Wall Wire Duct System, UL Listed - UL94 V0, M1 Fire Rated (CBMOWD2013) - cable raceway - TAA Compliant
Cable raceway
1.95 cm 1.38 cm
Length
2 m
190.9 g
Product Material
PVC
White
TAA Compliant
Cable raceway
Product Material
PVC
1.95 cm
1.38 cm
Length
2 m
190.9 g
Enclosure Colour
White
Self-extinguishing, adhesive tape, M1 Rated NF Fire Resistant
TAA Compliant
FXZZ StarTech.com Single Piece Wire Cable Raceway Duct - 32x20mm In Stock £9.46
