This single monitor stand enables you to raise your monitor off your desk or table to save space while increasing your productivity. With its durable aluminum construction and a sturdy base (7.8"x9.4" / 200mm x 240mm), it can support VESA compatible displays up to 32" and up to 15.4lb / 7kg in weight. The power coated black semi-gloss finish on the support column provides a professional and modern look that will match your monitor and workstation. Please refer to our technical specifications section for more information on the different aspect ratios supported.
Adjust your monitor to the ideal position
The free-standing monitor stand features a wide range of motion so you can position your monitor to the ideal viewing angle, allowing you to work more comfortably and reduce eye and neck strain. You can easily tilt +/-15°; swivel +/-180°; and make height adjustments to fully adjust your monitor so it can meet your ergonomic needs. With a rotating base, this monitor stand lets you swivel your display a total range of +/- 40°. -
Easy one-touch height adjustments
The spring-assisted monitor stand offers a total adjustment range of 10.4" to 16.3" (265mm to 415mm) from the surface or your desk. Height adjustments are easy to make with the built-in easy-access lever at the top of the stand. -
Keep a tidy setup and protect your desk
This monitor stand lets you keep an organized desk/workstation with the built-in cable management slot at the lower portion of the column. It is equipped with rubber anti-slip pads that will keep your desk or table surface protected from scratches or scuffs. FPPNEUSTND is backed by a StarTech.com 5-year warranty and free lifetime technical support.
- StarTech.com Free Standing Single Monitor Mount, Height Adjustable Monitor Stand, For VESA Mount Displays up to 32" (15lb/7kg), Ergonomic Monitor Stand for Desk, Tilt/Swivel/Rotate, Black - Universal Monitor Stand stand - adjustable arm - for Monitor - black
- Product Type
- Stand (adjustable arm) - desktop stand
- 20 cm x 24 cm x 57 cm
- Adjustable Height
- 26.5-41.5 cm
- Tilt
- -15° to 15°
- Rotation
- 180°
- Swivel
- -40° to 40°
- Adjustments
- Height, tilt, swivel, rotation
- 3.6 kg
- Recommended Use
- Monitor
- Recommended Display Size
- Up to 32"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Max Load Weight
- 7 kg
- Material
- Aluminium
- Black
- Package Content
- Base, hex key (5mm), screwdriver, hex key (6mm), 4 x M4x6 screws, 4 x M4x12 screws, 4 x M5x12 screws, 4 washers
- 5-year warranty
- 20 cm
- 24 cm
- 57 cm
- Adjustable Height
- 26.5-41.5 cm
- 3.6 kg
- Material
- Aluminium
- Black
- Package Content
AV Furniture
- Stand
- Design
- Adjustable arm
- Recommended Use
- Monitor
- Placing / Mounting
- Desktop stand
- Cable Management
- Integrated cable management
- Up to 32"
- Tilt
- -15° to 15°
- Rotation
- 180°
- Swivel
- -40° to 40°
- Adjustments
- Max Load Weight
- 7 kg
Dimensions & Weight Details
- Shipping Dimensions (WxDxH) / Weight
- 43.5 cm x 27.5 cm x 11.2 cm / 3.6 kg
- Limited warranty - 5 years
StarTech.com 3.5in Universal Hard Drive Mounting Bracket Adapter for 5.25in Bay | In Stock | £3.02 |
StarTech.com USB-C Multiport Adapter - SD - Power Delivery - 4K HDMI - GbE - 2x USB 3.0 | In Stock | £70.33 |
StarTech.com Thin Client Mount - VESA | In Stock | £23.04 |
StarTech.com USB-C Multiport Adapter HDMI - SD Reader - 2xA 1xC - PD3.0 | In Stock | £60.71 |
StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy | In Stock | £54.54 |
StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy | In Stock | £61.12 |
StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy | In Stock | £77.54 |
StarTech.com Slim Anti-Theft K-Slot Lock Plate Adapter for MacBook/Tablet/iPad/Phone/Laptop | In Stock | £7.52 |
StarTech.com Crossbar Dual Monitor Stand | In Stock | £86.32 |
StarTech.com Dual Monitor Vertical Mount | In Stock | £121.00 |
