Customized Boardroom Table Solution For Adding a Power, Charging, A/V, or Laptop Docking Module. Looking for connectivity right at your fingertips in a boardroom, huddle space, or classroom? The conference-table connectivity box is a customizable solution that lets you design unique connectivity applications.
Customize to Your Exact Needs
Combine any StarTech.com connectivity module (sold separately) with the single-module architectural connectivity box, to provide a solution that meets the exact needs of your space. Each module is interchangeable and provides easy-to-use solutions for connecting laptops and other devices.
StarTech.com module solutions can:
Add AC power and USB outlets for charging your devices (MOD4POWERNA)
Dock your laptop with boardroom peripherals, webcams, speakers, mics, and displays (MOD4DOCKACPD)
Connect in-room A/V equipment to laptops, Chromebook notebooks, and 2-in-1 laptops (MOD4AVHD, MOD4AVHDBT)
Declutter your space with cable organizers (MOD4CABLEH)
Easy, Stylish and Clean Installation
Design a practical and stylish solution that impresses your visitors and facilitates their needs. The connectivity box is easy to install in a table, desk or lectern, and features a black aluminum finish that complements your table and your peripherals.
BEZ4MOD is backed by a StarTech.com 2-year warranty and free lifetime technical support.
Combine any StarTech.com connectivity module (sold separately) with the single-module architectural connectivity box, to provide a solution that meets the exact needs of your space. Each module is interchangeable and provides easy-to-use solutions for connecting laptops and other devices. StarTech.com module solutions can: -
Design a practical and stylish solution that impresses your visitors and facilitates their needs. The connectivity box is easy to install in a table, desk or lectern, and features a black aluminum finish that complements your table and your peripherals. BEZ4MOD is backed by a StarTech.com 2-year warranty and free lifetime technical support.
- StarTech.com Single-Module Conference Table Connectivity Box-Customizable - mounting plate
- Product Type
- Mounting plate
- Package Content
- 2 wing fasteners, die-cut outline, lacing bar, 4 lacing bar screws (M4 x 4mm)
- 14.5 cm x 10 cm x 11.5 cm
- 1.1 kg
- Product Material
- Aluminium, steel
- Black
- 2-year warranty
- Product Type
- Mounting plate
- Package Content
- Product Material
- Aluminium, steel
- 14.5 cm
- 10 cm
- 11.5 cm
- 1.1 kg
- Enclosure Colour
- Black
- Shipping Weight
- 1.1 kg
- Limited warranty - 2 years
StarTech.com Dual-Module Conference Table Connectivity Box | In Stock | £81.05 |
StarTech.com Laptop Docking Module Conference Table Connectivity Box 4K | In Stock | £137.13 |
