StarTech.com Single-Module Conference Table Connectivity Bo
Quicklinx: FKDMWS00 Mfr#: BEZ4MOD
£29.76 ex VAT
£35.71 inc VAT
Customized Boardroom Table Solution For Adding a Power, Charging, A/V, or Laptop Docking Module. Looking for connectivity right at your fingertips in a boardroom, huddle space, or classroom?  The conference-table connectivity box is a customizable solution that lets you design unique connectivity applications.
Customize to Your Exact Needs
Combine any StarTech.com connectivity module (sold separately) with the single-module architectural connectivity box, to provide a solution that meets the exact needs of your space. Each module is interchangeable and provides easy-to-use solutions for connecting laptops and other devices.
StarTech.com module solutions can:
Add AC power and USB outlets for charging your devices (MOD4POWERNA)
Dock your laptop with boardroom peripherals, webcams, speakers, mics, and displays (MOD4DOCKACPD)
Connect in-room A/V equipment to laptops, Chromebook notebooks, and 2-in-1 laptops (MOD4AVHD, MOD4AVHDBT)
Declutter your space with cable organizers (MOD4CABLEH)
Easy, Stylish and Clean Installation
Design a practical and stylish solution that impresses your visitors and facilitates their needs. The connectivity box is easy to install in a table, desk or lectern, and features a black aluminum finish that complements your table and your peripherals.
BEZ4MOD is backed by a StarTech.com 2-year warranty and free lifetime technical support.
  • Customize to Your Exact Needs
    Combine any StarTech.com connectivity module (sold separately) with the single-module architectural connectivity box, to provide a solution that meets the exact needs of your space. Each module is interchangeable and provides easy-to-use solutions for connecting laptops and other devices. StarTech.com module solutions can:
  • Easy, Stylish and Clean Installation
    Design a practical and stylish solution that impresses your visitors and facilitates their needs. The connectivity box is easy to install in a table, desk or lectern, and features a black aluminum finish that complements your table and your peripherals. BEZ4MOD is backed by a StarTech.com 2-year warranty and free lifetime technical support.
StarTech.com Single-Module Conference Table Connectivity Box-Customizable - mounting plate
Mounting plate
Package Content
2 wing fasteners, die-cut outline, lacing bar, 4 lacing bar screws (M4 x 4mm)
14.5 cm x 10 cm x 11.5 cm
1.1 kg
Product Material
Aluminium, steel
Mounting plate
Package Content
Product Material
Aluminium, steel
14.5 cm
10 cm
11.5 cm
1.1 kg
Enclosure Colour
Shipping Weight
1.1 kg
FKDM StarTech.com Dual-Module Conference Table Connectivity Box In Stock £92.11
