Free up space while creating an ergonomic work environment. This desk-mount monitor arm makes it easy to securely mount and adjust a 17" to 34" display above your desk.
Adjust your monitor for ideal viewing
The single arm monitor mount extends up to 21.5" (547 mm) so it's easy to find the right viewing angle. Swivel your monitor +90/-90 degrees or tilt your screen +90/-90 degrees for comfortable viewing. You can even rotate it 180 degrees for landscape or portrait viewing. -
One-touch height adjustment
The slim monitor-mount arm features a mechanical spring that makes it easy to raise or lower your display, with up to 17.5" (445 mm) [AS1] of height adjustment. Adjust the tension according to the weight of your monitor for effortless movement. -
Easy installation
The VESA mount monitor stand is easy to install (desk C-clamp or grommet mount) and offers built-in cable management and dual USB 3.0 port passthrough for connecting your computer.
- StarTech.com Desk Mount Monitor Arm with 2x USB 3.0 ports, Slim Full Motion Adjustable Single Monitor VESA Mount up to 17.6lbs (8kg) Display, Ergonomic Articulating Arm, Desk Clamp/Grommet - One-touch Adjustment (ARMSLIM2USB3) mounting kit - Slim Full-motion - for LCD display/ curved LCD display - black
- Product Type
- Mounting kit (Slim Full-motion) - desk-mountable
- Mounting Components
- Articulating arm, desk clamp mount, grommet clamp
- Integrated Devices
- 2-ports USB 3.0 hub
- 11.5 cm x 54.7 cm x 44.5 cm
- Tilt
- -90° to 90°
- Swivel
- -90° to 90°
- Adjustments
- Height, tilt, swivel
- 2.85 kg
- Recommended Use
- LCD display/ curved LCD display
- Recommended Display Size
- 17"-34"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Max Load Weight
- 8 kg
- Material
- Heavy duty aluminium
- Black
- Package Content
- 4 x M4x12 screws, 4 x washers, 4 x M5x12 screws, hex key (3mm), grommet plate, hex key (6mm), cable management clip, grommet screw
- 2-year warranty
- 11.5 cm
- 54.7 cm
- 44.5 cm
- 2.85 kg
- Material
- Black
- Package Content
AV Furniture
- Mounting kit
- Design
- Slim Full-motion
- Recommended Use
- Placing / Mounting
- Desk-mountable
- Cable Management
- Integrated cable management
- 17"-34"
- Tilt
- -90° to 90°
- Swivel
- -90° to 90°
- Adjustments
- Max Load Weight
- 8 kg
Dimensions & Weight Details
- Shipping Dimensions (WxDxH) / Weight
- 43.5 cm x 24 cm x 11.7 cm / 3.5 kg
- Limited warranty - 2 years
StarTech.com USB-C Multiport Adapter - SD - Power Delivery - 4K HDMI - GbE - 2x USB 3.0 | In Stock | £68.98 |
StarTech.com Thin Client Mount - VESA | In Stock | £22.13 |
StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy | In Stock | £50.12 |
StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy | In Stock | £58.71 |
StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy | In Stock | £75.65 |
StarTech.com Slim Anti-Theft K-Slot Lock Plate Adapter for MacBook/Tablet/iPad/Phone/Laptop | In Stock | £7.34 |
