StarTech.com Shielded RJ45 Coupler, Cat6a
Quicklinx: HQ1NWS00 Mfr#: IN-CAT6A-COUPLER-S1
More than 50 In Stock
£14.40 ex VAT
£17.28 inc VAT
The StarTech.com Shielded RJ45 Coupler is a high-performance, inline Cat6a coupler designed to connect two CAT 6a network cables. This coupler is engineered to support data transfer speeds of up to 10 Gbps and distances up to 100 m, making it an excellent choice for extending your network. It features a passive adapter design with EMI protection and low insertion loss, ensuring a reliable and clear signal. The coupler is constructed with a durable metal housing and phosphor bronze contacts, capable of withstanding up to 750 mating cycles. Its PoE ready functionality also allows for the transmission of power along with data, making it a versatile component in any networking setup. With compliance to ANSI/TIA/EIA-568-C and TIA/EIA-568-B standards, and a Plug-and-Play feature, this coupler offers both ease of use and high standards of network performance.
  • Enhanced connectivity
    The Shielded RJ45 Coupler from StarTech.com offers a seamless connection between two CAT 6a cables, ensuring a stable and secure link for your network needs. Its design supports up to 10 Gbps transfer speeds and distances up to 100 m, making it ideal for extending your network reach without sacrificing performance.
  • Durable design
    Constructed with a robust metal housing and equipped with phosphor bronze contacts, this inline Cat6a coupler is designed for longevity. It withstands up to 750 mating cycles, offering reliable performance and durability for frequent plugging and unplugging.
  • Superior protection
    Featuring EMI protection and a shielded technology, this network coupler ensures minimal signal interference and low insertion loss. Its PoE ready feature also allows for the safe transmission of power over Ethernet, providing a versatile solution for various networking setups.
StarTech.com Shielded RJ45 Coupler, Inline Cat6a Coupler, F/F - network coupler - silver
Network coupler - CAT 6a
Shielded
Wiring Scheme
T568B
Passive adapter, metal housing, PoE ready, low insertion loss, up to 10 Gbps, 750 mating cycles, phosphor bronze contacts, EMI protection, up to 100 m transfer distance
Connector
RJ-45 - female
Connector (Second End)
RJ-45 - female
Silver
Network Cable Type
Shielded
Wiring Scheme
T568B
Plated Connector
Gold
1.6 cm
3.1 cm
2 cm
Silver
Connector
RJ-45 - female
RJ-45 - female
Plug and Play, TIA/EIA-568-B, ANSI/TIA/EIA-568-C
Shipping Width
12.5 cm
Shipping Depth
9 cm
Shipping Weight
10 g
-20 °C
65 °C
