StarTech.com SFP - HP J4858C Compatible
Quicklinx: C580WS00 Mfr#: J4858CST
Type: Modules
19 In Stock
£36.15 ex VAT
£43.38 inc VAT
Get reliable and cost-efficient Gigabit Ethernet connections over multi-mode fiber with this Mini-GBIC module. This HP compatible Gigabit fiber SFP is engineered by StarTech.com to deliver what you need most in your network connections: reliability. Built to exacting specifications and fully tested to ensure maximum performance, you can install this high-quality fiber transceiver module into HP networking devices that support the J4858C transceiver module, as well as other major brands of networking equipment.
This 1000Base-SX SFP delivers Gigabit connectivity over multimode fiber cable, with a range of up to 550 m (1804 ft.). It provides a dependable and cost-effective way to add, replace or upgrade the ports on your networking equipment. For large-scale requirements and maximum cost-savings, this GbE fiber SFP is also available in a 10-pack: J4858C10PKST.
This Gigabit SFP optical transceiver is manufactured by StarTech.com to meet or exceed OEM specifications and comply with the industry's MSA (Multi-Source Agreement) standards. Committed to the highest standards of quality, StarTech.com provides an extensive range of networking products including copper and fiber network cards, fiber media converters, Ethernet switches and wireless products.
The multimode Gigabit SFP is engineered to the highest quality standards and is 100% HP compatible, equivalent to the HP J4858C mini-GBIC. The StarTech.com SFP transceiver is configured and fully tested to ensure it works seamlessly with HP or other major brands of networking equipment.
You can be assured that the use of StarTech.com SFP products should not affect the warranty protection of your networking equipment.
Delivering both convenience and scalability, this fiber transceiver is fully hot-pluggable, which enables you to install it without interrupting network traffic or having to reboot your equipment. It provides a versatile and cost-effective solution that's compatible with a multitude of Gigabit networking devices.
Ideal for use in HP switches, routers and other networking equipment, the SFP provides reliable performance, allowing you to expand your network to remote segments cost-effectively. The SFP supports multimode fiber cable with a maximum distance of 550 m or 1804 ft., and maximum data rates of up to 1.25Gbps. This GbE fiber SFP also supports Digital Diagnostics Monitoring (DDM).
  • Efficient Data Transfer
    This module supports data transfer rates of 1.25 Gbps, providing a speedy means for transmitting information across the network.
  • Reliable Connectivity
    With compliance to Gigabit Ethernet standards and various protocols, this module ensures stable and accurate connections for all devices in the network.
  • Robust Environmental Tolerance
    The operating temperature range of 0 °C to 70 °C allows this module to perform optimally in diverse climate conditions, suitable for varied environments.
  • Enhanced Monitoring Capabilities
    Equipped with Digital Diagnostics Monitoring, this module facilitates real-time diagnostics and management, leading to improved network performance.
  • Flexible Installation Options
    The plug-in module design and use of LC multi-mode connectors enable easy installation and integration into existing network setups.
Startech HPE J4858C Compatible SFP Module, 1000BASE-SX, 1GbE Multi Mode (MMF) Fiber Optic Transceiver, 1GE Gigabit Ethernet SFP, LC Connector, 550m, 850nm, DDM, HPE 1400, 1700, 1820 - Lifetime Warranty (J4858CST) - SFP (mini-GBIC) transceiver module - 1GbE
SFP (mini-GBIC) transceiver module - LC multi-mode
Plug-in module
Cabling Type
1000Base-SX
Data Transfer Rate
1.25 Gbps
Optical Wave Length
850 nm
1GbE
Max Transfer Distance
550 m
HP J4858C
1.3 cm x 5.7 cm x 1.4 cm
P/N: IES101G2SFPW, IES101GP2SFW
Plug-in module
Silver
Wired
Cabling Type
1000Base-SX
1GbE
Data Transfer Rate
1.25 Gbps
Optical Wave Length
850 nm
550 m
Full duplex capability, half duplex mode, Digital Diagnostics Monitoring (DDM)
IEEE 802.3z
1 x Ethernet 1000Base-SX - LC multi-mode x 2
UL, FCC, RoHS, MSA
HP J4858C
1.3 cm
5.7 cm
1.4 cm
Limited warranty - lifetime
70 °C
30 - 75%
C580 StarTech.com 1m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £14.35
C580 StarTech.com 10m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £24.07
C580 StarTech.com 2m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £15.49
C580 StarTech.com 5m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £18.84
C580 StarTech.com 3m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £16.60
C580 StarTech.com PCI Express Gigabit Ethernet Fiber Network Card w/ Open SFP - PCIe SFP Network NIC In Stock £142.63
C580 StarTech.com Fiber Media Converter - Open In Stock £43.33
C580 StarTech.com SFP - HP J4858C Comp. 10 Pack In Stock £227.46
C580 StarTech.com SFP - HP J4858C Compatible In Stock £36.15
C580 StarTech.com Gb RJ45 SFP - HP Compatible In Stock £34.30
C580 StarTech.com SFP+ - HP JD092B Compatible In Stock £126.27
C580 StarTech.com SFP - HP J4859C Compatible In Stock £40.56
C580 StarTech.com Gb Copper SFP HP 453154-B21 Compatible In Stock £30.29
C580 StarTech.com 10 Gb SFP+ HP 455883-B21 Compatible In Stock £221.15
C580 StarTech.com HP JD089B Compatible SFP In Stock £37.38
C580 StarTech.com GbE Switch, 8x PoE+ 2x SFP Ports In Stock £328.89
Type: Modules
