StarTech.com SFP+ - HP J9151A Compatible
Quicklinx: C582WS00 Mfr#: J9151AST
Type: Modules
£154.31 ex VAT
£185.17 inc VAT
Ensure dependable 10Gb Ethernet connections and cost-savings with this single-mode Mini-GBIC module. This HP compatible 10 Gigabit fiber SFP+ is engineered by StarTech.com to deliver what you want most in your network connections: reliability. Built to exacting specifications and fully tested to ensure maximum performance, you can install this high-quality fiber transceiver module into HP networking devices that support the J9151A transceiver module, as well as other major brands of networking equipment.
This 10GBase-LR SFP+ delivers 10 Gigabit connectivity over single-mode fiber cable with a range of up to 10 km (6.2 mi.). It provides a dependable and cost-effective way to add, replace or upgrade the ports on your networking equipment.
This 10 GbE SFP+ is manufactured by StarTech.com to meet or exceed OEM specifications and comply with the industry's MSA (Multi-Source Agreement) standards. Committed to the highest standards of quality, StarTech.com provides an extensive range of networking products including copper and fiber network cards, fiber media converters, Ethernet switches and wireless products.
This 10 Gigabit single-mode SFP+ is engineered to the highest quality standards and is 100% HP compatible, equivalent to the HP J9151A SFP+ transceiver. The StarTech.com SFP+ transceiver module is configured and fully tested to ensure it works seamlessly with HP or other major brands of networking equipment.
You can be assured that the use of StarTech.com SFP products should not affect the warranty protection of your networking equipment.
Delivering both convenience and scalability, this fiber SFP+ transceiver is fully hot-pluggable, which enables you to install it without interrupting network traffic or having to reboot your equipment. It provides a versatile and cost-effective solution that's compatible with a wide range of 10 Gigabit networking devices.
Ideal for use in HP switches, routers and other networking equipment, the SFP+ optical transceiver provides reliable performance, allowing you to expand your network to remote segments cost-effectively. The SM fiber transceiver module supports Digital Diagnostics Monitoring (DDM), a maximum distance of up to 10 km (6.2 mi.), and maximum data rates of up to 10Gbps.
StarTech.com 10 Gb Fiber SFP+ - HP J9151A Compatible - SM LC -10km/6.2 mi - Lifetime Warranty (J9151AST) - SFP+ transceiver module - 10Mb LAN, 100Mb LAN, 1GbE, 10GbE
SFP+ transceiver module - LC single-mode
Plug-in module
Cabling Type
10GBase-LR
Data Transfer Rate
10 Gbps
Optical Wave Length
1310 nm
Max Transfer Distance
10 km
HP J9151A
1.3 cm x 5.7 cm x 1.4 cm
HP SFP+ zl Module Rack Shippable; HPE 2-Port SFP+/ 2-Port CX4 10GbE yl Module, 6120XG Blade Switch, 6600-24G-4XG Switch, 6600-48G-4XG Switch, SFP+ zl; HPE Aruba 2930F 24G 4SFP+, 2930F 48G 4SFP+, 2930F 48G PoE+ 4SFP+, 5406 zl
Plug-in module
Silver
Wired
Cabling Type
10GBase-LR
Data Transfer Rate
10 Gbps
Optical Wave Length
1310 nm
10 km
Full duplex capability, Digital Diagnostics Monitoring (DDM)
IEEE 802.3ae
1 x Ethernet 10GBase-LR - LC single-mode x 2
UL, FCC, RoHS, MSA
HP J9151A
1.3 cm
5.7 cm
1.4 cm
Limited warranty - lifetime
70 °C
30 - 75%
HP SFP+ zl Module Rack Shippable , HPE 2-Port SFP+/ 2-Port CX4 10GbE yl Module, 6120XG Blade Switch, 6600-24G-4XG Switch, 6600-48G-4XG Switch, SFP+ zl , HPE Aruba 2930F 24G 4SFP+, 2930F 48G 4SFP+, 2930F 48G PoE+ 4SFP+, 5406 zl
C582 StarTech.com SFP - HP J4858C Comp. 10 Pack In Stock £221.91
C582 StarTech.com SFP - HP J4859C Comp. 10 Pack In Stock £226.80
C582 StarTech.com SFP - HP J4858C Compatible In Stock £35.83
C582 StarTech.com Gb RJ45 SFP - HP Compatible In Stock £32.49
C582 StarTech.com SFP+ - HP J9151A Compatible In Stock £154.31
C582 StarTech.com SFP+ - HP JD092B Compatible In Stock £120.27
C582 StarTech.com SFP - HP J4859C Compatible In Stock £39.58
C582 StarTech.com Gb Copper SFP HP 453154-B21 Compatible In Stock £30.85
C582 StarTech.com 10 Gb SFP+ HP 455883-B21 Compatible In Stock £215.75
C582 StarTech.com HP JD089B Compatible SFP In Stock £35.41
Type: Modules
