StarTech.com Server Rack Cabinet Shelf
Quicklinx: GTBVWS00 Mfr#: SHELF-1U-20-FIXED-S
£55.88 ex VAT
£67.05 inc VAT
1U Fixed Server Rack Mount Shelf, 20in Deep Steel Universal Cantilever Tray for 19" AV/Data/Network Equipment Rack with Cage Nuts & Screws, 55lbs Weight Capacity, 20" Deep - 1U Network Rack Shelf (SHELF-1U-20-FIXED-S).
  • Reliable construction
    Made from sturdy SPCC cold rolled steel, this rack shelf ensures durability and performance under various conditions.
  • Ample weight capacity
    With a weight limit of 55 lbs, the shelf can handle the requirements of standard network and AV equipment.
  • Easy installation
    The included cage nuts, screws, and washers provide everything needed for installation, making setup quick and straightforward.
  • Standard compliance
    Meets EIA-310 and ECA-310 standards, ensuring compatibility with numerous rack-mounted applications.
  • Space efficiency
    Designed to fit in 19-inch racks, this shelf optimizes storage space in server rooms or audio/video setups.
StarTech.com 1U Fixed Server Rack Mount Shelf, 20in Deep Steel Universal Cantilever Tray for 19" AV/Data/Network Equipment Rack with Cage Nuts & Screws, 55lbs Weight Capacity, 20" Deep - 1U Network Rack Shelf - rack shelf - 1U
Rack shelf
Package Content
4 plastic washers, 4 M6 cage screws, 4 M6 square cage nuts
Rack Size
19"
Height (Rack Units)
1U
Product Material
48.3 cm x 50.8 cm x 4.3 cm
4 kg
Solid
Rack shelf
Product Material
Package Content
Rack Size
19"
Height (Rack Units)
1U
48.3 cm
50.8 cm
4.3 cm
4 kg
56 cm x 55 cm x 12 cm / 5.2 kg
Weight Limit
25 kg
Solid
EIA-310, ECA-310
Limited warranty: - lifetime
