1U Fixed Server Rack Mount Shelf, 20in Deep Steel Universal Cantilever Tray for 19" AV/Data/Network Equipment Rack with Cage Nuts & Screws, 55lbs Weight Capacity, 20" Deep - 1U Network Rack Shelf (SHELF-1U-20-FIXED-S).
- StarTech.com 1U Fixed Server Rack Mount Shelf, 20in Deep Steel Universal Cantilever Tray for 19" AV/Data/Network Equipment Rack with Cage Nuts & Screws, 55lbs Weight Capacity, 20" Deep - 1U Network Rack Shelf - rack shelf - 1U
- Product Type
- Rack shelf
- Package Content
- 4 plastic washers, 4 M6 cage screws, 4 M6 square cage nuts
- Rack Size
- 19"
- Height (Rack Units)
- 1U
- Product Material
- SPCC cold rolled steel
- 48.3 cm x 50.8 cm x 4.3 cm
- 4 kg
- Solid
- Limited lifetime warranty
- Product Type
- Rack shelf
- Product Material
- Package Content
- Rack Size
- 19"
- 1U
- 48.3 cm
- 50.8 cm
- 4.3 cm
- 4 kg
- Shipping Dimensions (WxDxH) / Weight
- 56 cm x 55 cm x 12 cm / 5.2 kg
- Weight Limit
- 25 kg
- Solid
- EIA-310, ECA-310
- Limited warranty: - lifetime
