1U Fixed Server Rack Mount Shelf, 12in Deep Steel Universal Cantilever Tray for 19" AV/Data/Network Equipment Rack with Cage Nuts & Screws, 55lbs Weight Capacity, 12" Deep - 1U Network Rack Shelf (SHELF-1U-12-FIXED-S).
Robust construction
Crafted from SPCC cold rolled steel, this 1U Fixed Server Rack Mount Shelf is designed to withstand the demands of any server environment, ensuring durability and reliability for your AV, data, and network equipment. -
Efficient space utilization
With a 12 in depth and a 1U height, this universal cantilever tray maximizes space efficiency in your 19" rack, providing a sturdy platform for your essential equipment without compromising on accessibility. -
Easy installation
The package includes 4 M6 cage screws, 4 M6 square cage nuts, and 4 plastic washers, facilitating a hassle-free setup process that securely mounts your equipment in place.
- StarTech.com 1U Fixed Server Rack Mount Shelf, 12in Deep Steel Universal Cantilever Tray for 19" AV/Data/Network Equipment Rack with Cage Nuts & Screws, 55lbs Weight Capacity, 12" Deep - 1U Network Rack Shelf - rack shelf - 1U
- Product Type
- Rack shelf
- Package Content
- 4 plastic washers, 4 M6 cage screws, 4 M6 square cage nuts
- Rack Size
- 19"
- Height (Rack Units)
- 1U
- Product Material
- SPCC cold rolled steel
- 48.3 cm x 30.5 cm x 4.3 cm
- 2.5 kg
- Solid
- Limited lifetime warranty
- Product Type
- Rack shelf
- Product Material
- Package Content
- Rack Size
- 19"
- 1U
- 48.3 cm
- 30.5 cm
- 4.3 cm
- 2.5 kg
- Shipping Dimensions (WxDxH) / Weight
- 37 cm x 55 cm x 12 cm / 3.2 kg
- Weight Limit
- 25 kg
- Solid
- EIA-310, ECA-310
- Limited warranty: - lifetime
