StarTech.com Server Rack Cabinet Shelf
Quicklinx: GTBSWS00 Mfr#: SHELF-1U-12-FIXED-S
Hurry, only 1 left in stock!
£34.00 ex VAT
£40.80 inc VAT
1U Fixed Server Rack Mount Shelf, 12in Deep Steel Universal Cantilever Tray for 19" AV/Data/Network Equipment Rack with Cage Nuts & Screws, 55lbs Weight Capacity, 12" Deep - 1U Network Rack Shelf (SHELF-1U-12-FIXED-S).
  • Robust construction
    Crafted from SPCC cold rolled steel, this 1U Fixed Server Rack Mount Shelf is designed to withstand the demands of any server environment, ensuring durability and reliability for your AV, data, and network equipment.
  • Efficient space utilization
    With a 12 in depth and a 1U height, this universal cantilever tray maximizes space efficiency in your 19" rack, providing a sturdy platform for your essential equipment without compromising on accessibility.
  • Easy installation
    The package includes 4 M6 cage screws, 4 M6 square cage nuts, and 4 plastic washers, facilitating a hassle-free setup process that securely mounts your equipment in place.
StarTech.com 1U Fixed Server Rack Mount Shelf, 12in Deep Steel Universal Cantilever Tray for 19" AV/Data/Network Equipment Rack with Cage Nuts & Screws, 55lbs Weight Capacity, 12" Deep - 1U Network Rack Shelf - rack shelf - 1U
Rack shelf
Package Content
4 plastic washers, 4 M6 cage screws, 4 M6 square cage nuts
Rack Size
19"
Height (Rack Units)
1U
Product Material
48.3 cm x 30.5 cm x 4.3 cm
2.5 kg
Solid
Rack shelf
Product Material
Package Content
Rack Size
19"
Height (Rack Units)
1U
48.3 cm
30.5 cm
4.3 cm
2.5 kg
37 cm x 55 cm x 12 cm / 3.2 kg
Weight Limit
25 kg
Solid
EIA-310, ECA-310
Limited warranty: - lifetime
