StarTech.com Serial to Ethernet Adapter
Quicklinx: HVMCWS00 Mfr#: I13-SERIAL-ETHERNET
16 In Stock
£120.17 ex VAT
£144.20 inc VAT
The StarTech.com Serial to Ethernet Adapter is a versatile, high-performance device designed to integrate RS232 serial devices into an IP-based Ethernet network. This adapter features a robust design that includes a DB-9 connector for RS-232 serial connection and an RJ-45 port for 100Base-TX Ethernet connection, making it ideal for a variety of industrial and commercial applications. With its wide operating temperature range (0°C to 60°C) and humidity tolerance (5 - 95% RH, non-condensing), it's built to perform reliably in challenging environments.
The adapter is engineered with advanced protection against electrostatic discharge, including 15 KV and 8 KV protection, ensuring the safety and longevity of your network equipment. It also boasts a comprehensive set of networking features, such as adjustable parity, auto-negotiation, and full duplex capability, enhancing its functionality and integration capabilities. Furthermore, its compliance with key industry standards, including EIA/TIA-232 and IEEE 802.3, ensures compatibility with a wide range of devices and networks. Whether you're looking to connect serial devices to an Ethernet network for remote management or integrate legacy equipment into modern infrastructures, this adapter offers a reliable, efficient solution.
  • Robust connectivity
    This Serial to Ethernet Adapter bridges the gap between RS232 and Ethernet networks, offering a DB-9 connector for RS-232 interface and an RJ-45 for 100Base-TX network connection. It's designed to provide reliable, seamless connectivity in various operating environments, with a humidity range operating from 5 - 95% RH and temperature tolerances from 0°C to 60°C.
  • Enhanced protection
    Equipped with 15 KV Electrostatic Discharge Protection and 8 KV Contact Electrostatic Discharge Protection, this adapter ensures your network's integrity is maintained against electrical surges, providing peace of mind and reducing the risk of damage to connected devices.
  • Advanced networking features
    Featuring adjustable parity, auto-negotiation, and full duplex capability, this device server supports efficient network communication and management. Its capabilities include flow control, manageable settings, and metal housing for durability, making it suitable for wall or DIN rail mounting.
  • Comprehensive standards compliance
    Adhering to EIA/TIA-232, IEEE 802.3i, and IEEE 802.3u standards, this adapter ensures compatibility with a wide range of network devices and systems. Its TAA compliance also makes it suitable for use in government and military applications.
  • Efficient data handling
    With a data transfer rate of up to 921.6 Kbps and support for Ethernet, Fast Ethernet, and RS-232 data link protocols, this adapter facilitates quick and reliable data transmission. It also supports TCP, Telnet, and UDP network/transport protocols for versatile network integration and remote management capabilities.
StarTech.com Serial to Ethernet Adapter, IP LAN to RS232 DB9 Converter - device server - TAA Compliant
Device server
Wall / DIN rail mountable
Ethernet, Fast Ethernet, RS-232
DIN-rail mounting kit, wall mounting kit
Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10 / 11
TAA Compliant
8.2 cm x 4.6 cm x 2.5 cm
155 g
Device server
8.2 cm
4.6 cm
2.5 cm
155 g
Enclosure Colour
Wired
Data Transfer Rate
921.6 Kbps
Network / Transport Protocol
Telnet, UDP, TCP
Routing Protocol
Static IP routing
Remote Management Protocol
Telnet, UDP
Status Indicators
Power, transmit, receive, link/activity
Flow control, full duplex capability, auto-negotiation, auto-uplink (auto MDI/MDI-X), manageable, 15 KV Electrostatic Discharge Protection, metal housing, 8 KV Contact Electrostatic Discharge Protection, adjustable parity
IEEE 802.3u, IEEE 802.3i
1 x RS-232 - DB-9 , 1 x 100Base-TX - RJ-45
EIA/TIA-232
TAA Compliant
External power adapter
Shipping Width
24.2 cm
Shipping Depth
16.6 cm
Shipping Height
5.5 cm
Shipping Weight
500 g
60 °C
5 - 95% RH (non-condensing)
HVMC StarTech.com Slimline DB9 Serial Gender Changer - F/F In Stock £4.77
HVMC StarTech.com DB9 to DB25 Serial Cable Adapter - F/M In Stock £5.43
HVMC StarTech.com PoE Serial to Ethernet Adapter In Stock £160.26
HVMC StarTech.com 2P Serial to Ethernet Adapter In Stock £184.30
HVMC StarTech.com 4P Serial to Ethernet Adapter In Stock £319.38
