StarTech.com Serial/Parallel PCI Card
Quicklinx: GGR2WS00 Mfr#: PCI2S1P2
Wired / Wireless: Wired
Protocol: RS-232
Form Factor: Plug-in card
Compatibility: [N/A]
Type: Serial adapter
£20.41 ex VAT
£24.49 inc VAT
PCI - RS-232 Serial - IEEE 1284 Parallel - Lifetime Warranty
This PCI 1x Parallel and 2x Serial Combo Card installs into a single PCI slot in your computer (occupying 2 to 3 expansion slots, depending on profile), and adds a DB25 IEEE 1284 parallel port and two DB9 RS 232 serial ports to your system.
Adds an LPT Parallel Port
The controller card features an Asix MCS9865 chip and enables you to connect a DB25 parallel device to your desktop computer. The parallel port is ideal for connecting printers, scanners, plotters, point-of-sale terminals, PLCs, scientific sensors, medical equipment or oscilloscopes. The parallel (LPT) port supports SPP/Byte/Nibble/ECP/EPP modes and IEEE 1284 for speeds up to 1.5Mbps.
Adds a COM Serial Port
The Asix MCS9865 chip also enables you to connect two DB9 devices using the same controller card, compatible with industry standard 16C550 UART. The serial ports are ideal for connecting point of sale terminals, serial printers, PLCs, control/automation in factories, scientific sensors, medical equipment, scanners and oscilloscopes. The serial (COM) ports support bi-directional RS232 speeds up to 115.2Kbps per port, available 256 byte FIFO buffer & 9th data bit.
Wide Installation Compatibility
With broad OS support, including for Windows (7 and up), and Linux (2.6.x to 5.x LTS versions only), this PCI serial/parallel card is easy to integrate into mixed environments. The card comes pre-configured with 2x full-profile brackets, and includes optional 3x low-profile brackets, so installation is easy regardless of the case form factor.
PCI2S1P2 is backed by a StarTech.com lifetime warranty with free 24/5 multi-lingual North American based technical support. StarTech.com has been the IT professionals' choice for over 30 years.
  • Adds an LPT parallel port
  • Adds a COM serial port
  • Wide installation compatibility
    With broad OS support, this PCI serial/parallel card is easy to integrate into mixed environments.
StarTech.com PCI Serial Parallel Combo Card with Dual Serial RS232 Ports (DB9) & 1x Parallel LPT Port (DB25), PCI Combo Adapter Card, PCI Expansion Card Controller, PCI to Printer Card - PCI Serial & Parallel Card (PCI2S1P2) - serial adapter - PCIe - RS-232 x 2
Serial adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express
Ports
RS-232 x 2
2.16 cm x 13.4 cm x 12 cm
141 g
Cabling Type
Serial RS-232
RS-232
Network / Transport Protocol
SPP
MCS9865
16C550 UART, IEEE 1284
Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Linux 2.6.x to 5.x LTS versions
Serial adapter
PCI Express
Ports
RS-232 x 2
Wired
Cabling Type
Serial RS-232
RS-232
SPP
ECP, 256-byte FIFO
Processor / Memory
MCS9865
2 x RS-232 - 9 pin D-Sub (DB-9)
2 x low-profile bracket, 1 x bracket with DB25 connector
FCC, RoHS
2.16 cm
13.4 cm
12 cm
141 g
Shipping Width
14.2 cm
Shipping Depth
17 cm
Shipping Height
3 cm
Shipping Weight
190 g
Limited warranty - lifetime
70 °C
10 - 90%
GGR2 StarTech.com DB9 to DB25 Serial Cable Adapter - F/M In Stock £5.43
Protocol: RS-232
