StarTech.com Serial Null Modem Adapter
Quicklinx: 76P7WS00 Mfr#: NM9FF
11 In Stock
£5.24 ex VAT
£6.28 inc VAT
This Null Modem Adapter features two DB9 female connectors - a cost-saving way to convert a straight through cable into a null modem cable.
  • Reliable connection
    Featuring dual 9-pin D-Sub (DB-9) female connectors, this adapter provides a consistent connection for serial communication between devices.
  • User-friendly design
    The straightforward Plug-and-Play design eliminates the need for complex setup, making it easy to connect and communicate between serial devices.
StarTech.com DB9 RS232 Serial Null Modem Adapter - F/F - Null modem adapter - DB-9 (F) to DB-9 (F) - NM9FF - null modem adapter - DB-9 to DB-9
Null modem adapter
Connector
9 pin D-Sub (DB-9) - female
Connector (Second End)
P/N: EC1S952, EC2S952, PCI2S232485I
Null modem adapter
Connector
76P7 StarTech.com Cisco Console Rollover Adapter for RJ45 Ethernet Cable M/F In Stock £5.58
