The RS232EXTC1GB Serial over Cat 5 Extender allows you to increase the distance of your RS232 Serial connection by up to 1000 meters (3300 feet), giving you the ability to connect serial peripheral devices up to a kilometer away from your system - an incredible 65x greater than normal RS232 serial cable length restrictions would permit.
The Extender is a cost-effective serial extension solution and completely hardware-based, eliminating the need to install additional software, allowing for a completely plug and play installation. The hardware can be setup in minutes, using Cat 5 or better Ethernet cabling.
Perfect for use in industrial monitoring and control, POS, security, medical, and traffic flow applications, the RS232 Serial over Cat 5 extender maintains the RS232 standard with support for data transfer rates of up to 230 Kbps.
- StarTech.com Serial DB9 RS232 Extender over Cat 5 - Up to 3300 ft (1000 meters) - serial port extender
- Serial port extender
- Form Factor
- External
- Localisation
- United Kingdom
- Data Transfer Rate
- 230 Kbps
- Transmission Medium
- CAT 5
- Max Transfer Distance
- 1 km
- 2-year warranty
- Form Factor
- External
- Localisation
- United Kingdom
- Connectivity Technology
- Wired
- 230 Kbps
- 1 km
- 1 x RS-232 - DB-9
- Limited warranty - 2 years
StarTech.com DC Power Adapter - 9V, 2A | In Stock | £12.30 |
