20 Pack Outside T Connector White UL Approved. This 20-pack of raceway T connectors work with the StarTech.com CBMCWD5020 raceway system.
Join Three Raceways Together in a T-Bar Configuration
Use these cable raceway T connectors with the StarTech.com CBMCWD5020 raceway to join three of them together in a T-bar configuration in your office or server room.
Industrial Strength
Made from sturdy self-extinguishing ABS that's also warp proof, these wiring duct connectors are UL approved with 94HB Flamability (Horizontal Burning) Rating.
Use in Combination with Other Raceway Accessories
Combine this T connector with other StarTech.com CBMCWD5020 raceway system accessories to give your cable management solution a finished look.
The Coupler (CBMCWD5020C) (20-Pack), joins two raceways together and extends the length of your raceway.
The End Piece (CBMCWD5020E) (20-Pack), cleanly caps off the end of your raceway.
The Inside Elbow (CBMCWD5020I) (20-Pack), joins two raceways together inside of corners at 90 degree angle.
The Lateral Elbow (CBMCWD5020L) (20-Pack), joins two raceways together and runs them up the wall at a 90 degree angle.
The Outside Elbow (CBMCWD5020O) (20-Pack), joins two raceways together around corners at a 90 degree angle.
These cable management raceway T connectors are TAA compliant and backed by a StarTech.com Lifetime warranty and free 24/5 technical support. StarTech.com has been the IT professionals choice for over 30 years.
Join two raceways together and run them up the wall at a 90 degree angle
Use these cable raceway lateral elbows with the CBMWWD5020 raceway to join two of them together at a 90 degree angle to extend the length of your raceway up walls in your office or server room. -
Industrial strength
Made from sturdy self-extinguishing ABS that's also warp proof, these wiring duct elbow connectors are UL approved with 94HB Flamability (Horizontal Burning) Rating.
- StarTech.com 20 Pack Cable Raceway T Connector for CBMCWD5020, Cable Management Accessories, 3 Way Raceway Fitting Connectors, T Type Connector, Wiring Duct Tee Connector, UL Listed - ABS Plastic, UL94 HB (CBMCWD5020T) - cable raceway T connector - TAA Compliant
- Product Type
- Cable raceway T connector
- Packaged Quantity
- 20 (specifications are for single item)
- 9.411 cm x 7.4 cm x 2.202 cm
- 18 g
- Product Material
- Acrylonitrile butadiene styrene (ABS)
- White
- TAA Compliant
- 2-year warranty
- Designed For
- P/N: CBMCWD5020
- Packaged Quantity
- Product Type
- Product Material
- 9.411 cm
- 7.4 cm
- 2.202 cm
- 18 g
- Enclosure Colour
- White
- Self-extinguishing, UL rated
- TAA Compliant
- Shipping Width
- 40.5 cm
- Shipping Depth
- 28.1 cm
- Shipping Height
- 10 cm
- Shipping Weight
- 400 g
- Limited warranty - 2 years
- Designed For
- P/N: CBMCWD5020
