20 Pack Coupler Connector White UL Approved. This 20-pack of raceway couplers work with the StarTech.com CBMCWD5020 raceway system.
Join Two Raceways Together
Use these cable raceway couplers with the StarTech.com CBMCWD5020 raceway to join two of them together and extend the length of your raceway in your office or server room.
Industrial Strength
Made from sturdy self-extinguishing ABS that's also warp proof, these wiring duct connectors are UL approved with 94HB Flamability (Horizontal Burning) Rating.
Use in Combination with Other Raceway Accessories
Combine this coupler with other StarTech.com CBMCWD5020 raceway system accessories to give your cable management solution a finished look.
The End Piece (CBMCWD5020E) (20-Pack), cleanly caps off the end of your raceway.
The Inside Elbow (CBMCWD5020I) (20-Pack), joins two raceways together inside of corners at 90 degree angle.
The Lateral Elbow (CBMCWD5020L) (20-Pack), joins two raceways together and runs them up the wall at a 90 degree angle.
The Outside Elbow (CBMCWD5020O) (20-Pack), joins two raceways together around corners at a 90 degree angle.
The T Connector (CBMCWD5020T) (20-Pack), joins three raceways together in T-bar.
This cable management raceway coupler is TAA compliant and backed by a StarTech.com Lifetime warranty and free 24/5 technical support. StarTech.com has been the IT professionals choice for over 30 years.
Professionally organize & route cables with 3 individual channels
This cable management raceway protects cables from damage while neatly routing them in your office or server room. The raceway is 0.8 in. (20 mm) x 2 in. (51 mm) with three individual channels running throughout the raceway you can use to easily organize and separate cables. -
Industrial strength
Made from self extinguishing PVC, that's sturdy and warp proof this network/power cable hider/concealer is M1 Rating NF fire resistant with a 186F (86C) Vicat softening point and are UL/94V-0 Rated. -
Hassle-free installation
The cable raceway can be mounting by simply drilling holes through housing and into any surface, or double sided tape can used to secure the raceway.
- StarTech.com 20 Pack Cable Raceway Coupler for CBMCWD5020, Cable Management Accessories, Channel Raceway Fitting Coupler, Midway Connectors, Wiring Duct Straight Connector, UL Listed - ABS Plastic, UL94 HB (CBMCWD5020C) - cable raceway coupler - TAA Compliant
- Product Type
- Cable raceway coupler
- Packaged Quantity
- 20 (specifications are for single item)
- 5.43 cm x 3.43 cm x 2.2 cm
- 6 g
- Product Material
- Acrylonitrile butadiene styrene (ABS)
- White
- TAA Compliant
- 2-year warranty
- Designed For
- P/N: CBMCWD5020
- Packaged Quantity
- Product Type
- Product Material
- 5.43 cm
- 3.43 cm
- 2.2 cm
- 6 g
- Enclosure Colour
- White
- Self-extinguishing, UL rated
- TAA Compliant
- Shipping Width
- 23 cm
- Shipping Depth
- 21.3 cm
- Shipping Height
- 5 cm
- Shipping Weight
- 130.77 g
- Limited warranty - 2 years
- Designed For
- P/N: CBMCWD5020
