StarTech.com Security Tether Cables - 10 Pack - Steel - Universal Cable a
Quicklinx: FLXNWS00 Mfr#: CONNLOCKPK10
Device Type: Other
Type: Security
Device Screen Size: [N/A]
Colour: Silver
40 In Stock
£23.38 ex VAT
£28.05 inc VAT
Secure cables and adapters in boardrooms, workstations and other areas to help prevent against costly theft or accidental loss. These steel security tether cables provide a measure of physical security, by letting you attach your cables and adapters to each other.
The 10-pack of universal cable tethers give you an easy and cost-effective way to minimize the need to constantly replace cables in lobbies, public areas, work and meeting areas. They secure your cables and adapters, and also keep cables organized by making sure you always have the right adapter or cable in the right place.
The cable and adapter tethers are made of a durable steel cable with a PVC coating, providing an effective theft deterrent.
The flexible steel security cable is easy to wrap around your cables or adapters, and secure in place with the aluminum ferrules, using a standard crimping tool (not included). For versatile use, you can cut the 11.8" (300 mm) cable tethers to length, using wire cutters (not included). The steel tether does not restrict the space requirements or usage of the cable or adapter.
As an option, you can cover the aluminum ferrules with the black heat shrink tubing (included).
  • Reliable security solution
    Designed to keep adapters and dongles securely tethered, minimizing loss or theft scenarios.
  • Environmentally compliant materials
    Manufactured from materials that meet RoHS and REACH standards, showcasing commitment to safety and sustainability.
StarTech.com 10-Pack Security Cable Tethers for Adapters & Dongles, Universal Cable Adapter Tether, Tether Cables, Adjustable Length Anti-Theft Cable Tether Lock Kit, Steel Cable Tether - Dongle Cable Tether (CONNLOCKPK10) - security cable - TAA Compliant
Security cable
Packaged Quantity
10 (specifications are for single item)
Package Content
20 heat shrink tubings, 20 x aluminium ferrules
Silver
Product Material
Steel
0.22 cm x 30 cm x 0.22 cm
Length
30 cm
29 g
TAA Compliant
Packaged Quantity
Security cable
Product Material
Steel
Package Content
0.22 cm
30 cm
0.22 cm
Length
30 cm
29 g
22 cm x 20 cm x 0.5 cm / 73 g
Silver
RoHS, REACH
TAA Compliant
Limited warranty: - 2 years
Device Type: Other
Type: Security
Colour: Silver
