StarTech.com Secure tablet stand, Desk/wall
Quicklinx: GVL0WS00 Mfr#: SECTBLTPOS2
Accessory Type: Display mounting kit
£106.16 ex VAT
£127.39 inc VAT
The secure iPad enclosure lets you set up a tablet as a point of sales (POS) system in your business or for secure product displays. It supports the 10.2" iPad (7/8th gen), 10.5" iPad Air (3rd gen), 10.5" iPad Pro (2nd gen), or other 10.2"/10.5" tablets.
  • Secure and Protected
    The enclosure protects your tablet from tampering and theft using a lock and key, and for enhanced security, it has two K-slots at the back. The display is fully accessible while blocking the buttons from access. The all-steel construction makes for a sturdy enclosure that protects and shields the tablet from day-to-day wear and tear.
  • Multiple mounting options
    Using the included 30° angled bracket you can use it as a stand or use it to securely mount the enclosure to any flat surface while keeping the display easy to see. The VESA 100x100 pattern provides additional installation options for monitor mounts, arms, or stands that support 2.2 lbs (1.0 kg) or higher. You can mount the enclosure to the bracket in portrait or landscape mode to better suit the viewing angle or content displayed.
  • Functional design
    Create a seamless surface between the display and enclosure using the included pads that allow the tablet to sit closer to the display opening (8.5x6.4 in / 217.5x164 mm). You can power your tablet while it's secured by routing the power cable inside the enclosure to the rear. The SECTBLTPOS2 is backed for 5-years by StarTech.com, including free lifetime 24/5 multi-lingual technical assistance.
StarTech.com Secure Tablet Stand, Anti Theft Universal Tablet Holder for Tablets up to 10.5", Lockable Tablet Stand for Desk/ K-Slot Compatible, VESA Mount, Wall Mount Tablet Enclosure - Security POS Tablet Stand (SECTBLTPOS2) stand - for tablet - black
Stand - wall-mountable, desktop, VESA bracket mounting - lockable
32.4 cm x 18.2 cm x 1.9 cm
Rotation
180°
1.9 kg
Recommended Use
Tablet
Recommended Display Size
10.5"
VESA Mounting Interface
100 x 100 mm
Max Mounting Pattern Size
100 x 100 mm
Material
Steel
Package Content
2 keys, 4 x M4x10 screws, tablet enclosure, 2 x felt tape (200mm x 5mm), 2 x felt tape (150mm x 10mm), 4 x EVA pads (20mm x 15mm x 3mm), 2 x EVA pads (45mm x 15mm x 2mm), 2 x foam blocks (100mm x 25mm x 20mm), 2 x foam blocks (100mm x 15mm x 12mm), M2.5 hex key, 3 x 5x20m self tapping screws, 3 x washers (small), 2 x washers (large), 4 x rubber pads
5-year warranty
32.4 cm
18.2 cm
1.9 cm
1.9 kg
Material
Steel
Package Content
AV Furniture
Stand
Recommended Use
Tablet
Placing / Mounting
Wall-mountable, desktop, VESA bracket mounting
100 x 100 mm
100 x 100 mm
Lockable
10.5"
Rotation
180°
Dimensions & Weight Details
35 cm x 25 cm x 15 cm / 2.4 kg
Limited warranty - 5 years
GVL0 StarTech.com Lightning/Micro USB Cable In Stock £16.51
GVL0 StarTech.com 1 m / 3.3 ft USB 2.0 to USB C Cable – Black In Stock £9.14
GVL0 StarTech.com 2 m / 6.6 ft USB 2.0 to USB C Cable – Black In Stock £9.99
GVL0 StarTech.com 1 m / 3.3 ft USB C Cable – Black In Stock £9.36
GVL0 StarTech.com Universal Laptop Lock, 3-in-1 In Stock £31.21
GVL0 StarTech.com 25-Pack Universal Laptop Lock In Stock £582.27
GVL0 StarTech.com 25-Pack Universal Laptop Lock In Stock £608.45
GVL0 StarTech.com 25-Pack Universal Laptop Lock In Stock £645.19
GVL0 StarTech.com 3-in-1 Universal Laptop Lock In Stock £28.42
