StarTech.com Secure Charge USB Data Blocker Adapter
Quicklinx: GB6HWS00 Mfr#: USBSCHAAMF
Length: [N/A]
22 In Stock
£5.15 ex VAT
£6.18 inc VAT
Data Blocker USB Charger USB-A male to USB-A female adapter 5V, 2.4A (12W) 2-Year Warranty. This USB-A male to USB-A female Data Blocker adapter lets you securely charge your device by establishing a power-only connection between your device and the host system or power source. Equipped with no-data USB-A male connector with a unique cut-away design, this secure adapter prevents malware attacks and data thefts, and provides a safe way to charge your mobile devices.
Power-Only USB-A to A Adapter
The USB-A male port of this adapter does not have physical data pins, resulting in an adapter with physical barrier for data transmission. This adapter allows you to charge your mobile devices from a laptop or desktop computer while eliminating any possibility of
Data theft from the host computer
Data corruption on the host computer
Infection from spyware/malware or viruses being transmitted from the mobile device to the host network
Handy Adapter for Everyday Use
Portable 1.3"L x 0.7"W x 0.4"H adapter fits into your pocket or laptop bag, and lets you safely charge your smart phones, tablets, headphones, cameras, etc. in public charging stations/ports in airports, hotels and restaurants. Absence of data lines also makes this adapter safe to use in government, defense, corporate and educational environments, where connecting your mobile device may be prohibited.
Smart, Powerful and Versatile Cable
High throughput adapter delivers 5V up to 2.4A (12W max.). Smart on-board chip identifies the device's power requirements and adjusts the output accordingly. Use your existing USB-A to C, Lightning, micro-B cables to charge your appropriate devices from all USB-A power outlets - from host computers to wall chargers.
Robust and Reliable Construction
The adapter's mold is made from tough TPE plastic that offers high resilience to fraying and scratches, making it ideal for everyday rough use. Aluminium-Mylar foil shielding provides noise-free DC power to your device.
Comprehensive Product Testing & Expert Technical Support
StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to our customers. Our local StarTech.com Technical Advisors have a broad product expertise and work directly with StarTech.com Engineers to provide support for our customers both pre and post-sales.
USBSCHAAMF is backed by a StarTech.com 2-year warranty.
  • USB-A data blocker adapter
    Charge-Only design without data pins provides physical data blocking, prevents data theft/corruption and leak prevention while stopping spyware/malware attacks on smartphones, tablets & battery powered mobile devices.
  • Secure charging adapter
    Tiny pocket sized adapter is easy to carry, charge devices anywhere using your data blocking charger cable adapter, Ideal for high-security use in public, corporate, defense & educational environments.
  • Versatile adapter
    The USB Data Protector delivers 5V at 2.4A (12W max) & works with all USB-A cables and hosts so you can use your existing USB-A to C/Lightning/Micro-USB cable to charge your devices.
  • Robust construction
    Durable and Rugged enclosure built for portability and on the go use with public charging ports in airports, shopping malls & hotels, recommended cables: RUSBLTMM1MB (Lightning), RUSB2AC1MB(USB-C).
StarTech.com Secure Charging USB Data Blocker Adapter, Male to Female USB-A Charge-Only Adapter, No-Data Charge/Power-Only Adapter for Phone/Tablet, Data Blocking USB Protector Adapter - 5V, 2.4A (12 W) Max (USBSCHAAMF) - USB charge adapter - USB (power only) to USB (power only)
USB charge adapter
Passive adapter
Connector
4 pin USB Type A (power only) - female
Connector (Second End)
4 pin USB Type A (power only) - male
Rated Voltage
5 V
Rated Current
2.4 A
USB charge adapter
Jacket Material
Thermoplastic elastomer (TPE)
Rated Voltage
5 V
Rated Current
2.4 A
Plated Connector
Nickel
Passive adapter
1.8 cm
3 cm
1 cm
6.9 g
Connector
WEEE, RoHS 2011/65/EU, REACH 2006/1907
Shipping Width
12.5 cm
Shipping Depth
9 cm
Shipping Weight
8.9 g
Length: [N/A]
