Connect your HDMI Display to an SDI Video Source. The SDI2HD 3G SDI to HDMI converter enables you to turn a 3G SDI video signal into an HDMI video output. The adapter features a built-in 3G SDI daisy chain port, giving you the ability to further extend the SDI source to up to 755ft (230m) over standard coaxial cable, for large scale HD-SDI video broadcasting distribution.
To ensure you maintain perfect high-definition video quality the SDI-HDMI converter features supports resolutions up to 1080p, allowing you to convert SDI to HDMI without sacrificing video quality.
For hassle-free installation, the SDI to HDMI converter offers a plug-and-play solution that includes pre-installed mounting brackets and requires no software or driver installation.
- StarTech.com SDI to HDMI Converter - 3G SDI to HDMI Adapter with SDI Loop Through Output - SDI to HDMI Audio/Video Adapter - 755ft (230m) (SDI2HD) - video converter - black
- Video converter
- Max Resolution
- 1920 x 1200
- 1 x HDMI output - 19 pin HDMI Type A , 1 x 3G-SDI input - BNC , 1 x 3G-SDI output - BNC
- 10 cm x 7 cm x 2.5 cm
- Enclosure Colour
- Black
- 2-year warranty
- Video converter
- Max Resolution
- 1920 x 1200
- 1 x HDMI output - 19 pin HDMI Type A - female , 1 x 3G-SDI input - BNC - female , 1 x 3G-SDI output - BNC - female
- Voltage Required
- AC 120/230 V
- FCC, RoHS
- 10 cm
- 7 cm
- 2.5 cm
- 202 g
- Enclosure Colour
- Black
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 5 - 90% (non-condensing)
StarTech.com DC Power Adapter - 5V, 3A | In Stock | £11.75 |
StarTech.com DisplayPort VGA HDMI Converter Switch | In Stock | £267.59 |
