The StarTech.com USB-C SD Express Card Reader is a versatile device designed for seamless connectivity. Featuring an external aluminum housing, this card reader is durable and lightweight, making it easy to carry for on-the-go use. With its USB-C 3.2 Gen 2 interface, it supports data transfer speeds of up to 10 Gbps, enabling quick access to your files and simplifying data management.
This card reader supports both SDHC and SDXC memory cards, allowing for compatibility with a variety of devices. Furthermore, it supports microSD and miniSD formats with the use of an adapter, providing additional flexibility. Bus-powered for convenience, this reader operates without the need for external power, ensuring that it is ready when you are.
Efficient data transfer
With support for USB-C 3.2 Gen 2, this card reader offers data transfer speeds of up to 10 Gbps, reducing waiting times and enhancing productivity. -
Broad memory compatibility
This card reader is compatible with SDHC and SDXC memory cards, and with an adapter, it can also work with microSD and miniSD formats, ensuring versatility for various users. -
Portable design
The lightweight and compact design of the aluminum housing makes it ideal for travel, fitting easily into bags or pockets for on-the-go access to your memory cards. -
Bus-powered convenience
This card reader is bus-powered, meaning it draws power directly from the USB-C connection, eliminating the need for additional power sources and making it easy to use anywhere.
- StarTech.com USB-C SD Express Card Reader, USB 10Gbps, Portable Memory Card Reader, USB Type-C to Secure Digital 7.1 Adapter, Works with Any Operating System - card reader - USB-C 3.2 Gen 2
- Product Type
- Card reader - external
- Supported Memory Cards
- SDHC Memory Card, SDXC Memory Card
- Host Interface
- USB-C 3.2 Gen 2
- Black
- Aluminium housing, bus-powered, up to 10 Gbps data transfer
- 2-year warranty
- Product Type
- Supported with Optional Adapter
- microSD, miniSD
- Host Interface
- USB-C 3.2 Gen 2
- Black
- 5.4 cm
- 27.4 cm
- 1.4 cm
- 60 g
Memory Card
- Capacity
- (max)
- Required Ports
- 1 x 24 pin USB-C
- OS Required
- Apple MacOS, Google Chrome OS, Microsoft Windows, Linux
- Shipping Width
- 14.2 cm
- Shipping Height
- 3 cm
- Shipping Weight
- 63 g
- Limited warranty - 2 years
StarTech.com CFexpress Type B Card Reader | In Stock | £19.18 |
StarTech.com SD Express Card Reader
